Message 1 of 1
Updating existing CSV spline by new CSV points?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Im struggling to find any way how to update existing spline created from CSV points by a new data set without loosing dependencies with the following geometries. I tried to delete the spline fit points and uploading new ones, but it freezes the program. Deleting and recreating the spline works but looses the dependencies. Im now out of ideas, so any help would be appreciated.
Thanks in advace
"""This file acts as the main module for this script.
Skript pro upload meridionalniho rezu generovanych ve Scilabu
Nutno puzit pouze se spravnym modelem ve Fusion
Pak je nutno ruzne opravit zavislosti
import traceback
import adsk.core
import adsk.fusion
import adsk.cam
import csv
import tkinter as tk
from tkinter import filedialog
import os
# Initialize the global variables for the Application and UserInterface objects.
app = adsk.core.Application.get()
ui = app.userInterface
design = app.activeProduct
def get_sketch_index_by_name(sketch_name): #funkce pro urceni indexu sketche dle jeho jmena
try:
root_comp = design.rootComponent
# Get all sketches in the root component
sketches = root_comp.sketches
# Iterate through sketches to find the one with the specified name
for i in range(sketches.count):
sketch = sketches.item(i)
if sketch.name == sketch_name:
return i # Return the index (item number)
# If no sketch with the given name is found
return None
except:
return None
def read_csv_points(file_path):
points = []
try:
with open(file_path, mode='r') as file:
reader = csv.reader(file)
for row in reader:
if len(row) == 3: # Assuming the CSV has x, y, z columns
points.append(adsk.core.Point3D.create(float(row[0]), float(row[1]), float(row[2])))
except Exception as e:
print(f"Error reading CSV file: {e}")
return points
def update_sketch_profile(target_sketch_name, csv_file_path):
try:
# Access the root component
# Read points from the CSV
csv_points = read_csv_points(csv_file_path)
if not csv_points:
ui.messageBox("No valid points found in the CSV file.")
return
# Convert the list of points into an ObjectCollection
point_collection = adsk.core.ObjectCollection.create()
for point in csv_points:
point_collection.add(point)
# Get the item number for the sketch
sketch_index = get_sketch_index_by_name(target_sketch_name)
if sketch_index is None:
ui.messageBox(f"Sketch '{target_sketch_name}' not found.")
target_sketch = sketches.item(sketch_index)
splines = target_sketch.sketchCurves.sketchFittedSplines
if splines.count == 0:
ui.messageBox("No splines found in the target sketch.")
return
# Delete the existing spline
existing_spline = splines.item(0) # Adjust the index for the correct spline
existing_spline.deleteMe()
# Create a new spline with the updated points
new_spline = target_sketch.sketchCurves.sketchFittedSplines.add(point_collection)
#nize je novy zpusob pouze modifikovani bodu splinu
spline = splines[0] # Modify the first spline in the sketch
# Defer sketch computations to improve performance
target_sketch.isComputeDeferred = True
fit_points = spline.fitPoints
for i in range(fit_points.count - 1, -1, -1): # Start from the last index
fit_points.item(i).deleteMe()
for point in point_collection:
spline.fitPoints.add(point)
# Reactivate sketch computations
target_sketch.isComputeDeferred = False
# Update the sketch to reflect changes
#target_sketch.sketchCurves.addFitPointSpline(csv_points)
except: #pylint:disable=bare-except
# Write the error message to the TEXT COMMANDS window.
app.log(f'Failed:\n{traceback.format_exc()}')
ui.messageBox(f"Failed:\n{traceback.format_exc()}")
return None
def run(_context: str):
"""This function is called by Fusion when the script is run."""
try:
# Your code goes here.
ui.messageBox(f'"{app.activeDocument.name}" is the active Document.')
#dialog pro otevreni adresare se soubory krivek kompresoru
root = tk.Tk()
root.withdraw() # Hide the main tkinter window
folder_path = filedialog.askdirectory(title="Select Folder with CSV Files")
print(f"Selected folder: {folder_path}")
csv_file_path1 = os.path.join(folder_path, 'Meridian_pata.csv')
csv_file_path2 = os.path.join(folder_path, 'Meridian_spicka.csv')
# Suspend updates
#design.freezeUpdates = True
update_sketch_profile('merid-pata',csv_file_path1)
update_sketch_profile('merid-spicka',csv_file_path2)
# Resume updates
#design.freezeUpdates = False
ui.messageBox("Curve updated from CSV successfully!")
# Resume updates
