Units for api
Units for api
Cotral.RD2
Message 1 of 8
Units for api
Cotral.RD2
Has there been any updates on the default units for the sketcher?
The last lime i checked two days back the dimension from api i got was in radians for angles and cms for lengths, but now it seems the units are changed to mm and deg..
Its a good move but i need to be sure this is truly the case..
Pavan HEMMEGE VENKATAPPA
Fusion 360 Ultimate User
Replies (7)
Message 2 of 8
BrianEkins
What calls are you using to get those values?  The API should always return distances in centimeters and angles in radians.
Brian Ekins
Message 3 of 8
Cotral.RD2
Ah my mistake!
yes when i get the values directly to a variable the units are in centimeters and radians but since i was transferring this value directly to a command input with mm and deg units the conversion happened automatically
Message 4 of 8
maxim.yudayev3RJDX
Brian,
Is there a list of standard units that the Units Manager recognises? The documentation does not specify this. I am interested in using angular velocity units passed from user in RPM.
Thank you.
-Max
Message 5 of 8
BrianEkins
There should be something in the documentation about this but I didn't think about it at the time because the API supports whatever core Fusion supports since it's just using internal utilities.  One way to see what's supported is to run the Parameters command and create a new user parameter.  You can choose the unit for the new parameter which will display a large list of unit types.  There is an option for angular velocity as rpm.  One thing to be aware of though is that the API always deals with consistent internal units, which are cm for length, radians for angles, seconds for time, and kilograms for mass. So if the user enters "5 rpm" and you get back the value you'll get
0.5235987755982988, which is 5 rpm expressed as radians/second.
Brian Ekins
Message 6 of 8
maxim.yudayev3RJDX
Brian,
Hahaha, I actually found it right the same way a few minutes before you had left a reply! Thank you sir!
Yes, you always mention in similar threads that F360 interprets and evaluates the values in those fixed units.
Though I now have a new problem, I can't wrap my head around why I am unable to choose a "No Units" value for an addValueInput. Can you please give an advice? I had tried different spelling and letter casing, can't seem to find the right way.
Thank you very much.
-Max
Message 7 of 8
BrianEkins
An empty string should work to create a parameter with no units.
addValueInput('safetyFactor', 'Safety Factor', '', 1)
Brian Ekins
Message 8 of 8
maxim.yudayev3RJDX
Tried it before, but apparently it was only part of the issue, i declared number "1" in stead of "ValueInput.createByReal(1)" as the initial value for that input.
Thank you very much for the tips, the issue is solved!
