Unit about Moments of Inertia returned by API
11713013
11713013
It seems an error about unit for moment of inertia returned by Fusion360 API.
In the document of Fusion360 API, the unit of MoI is kg/cm^2. However, unit for MoI should be mass*length^2.
The unit of MoI displayed in the UI is g mm^2.
So, what exactly is the unit for MoI returned by Fusion360 API?
Rushikesh.kadam
@11713013 Thank you for reporting the case. I have created a ticket to correct it.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
This is so funny because so several post have mentioned kg/cm^2 but did not point this error that makes me very confused.
So, the correct unit that returned by the API is kg*cm^2, right?
Rushikesh.kadam
@11713013 Yes, the correct unit returned by API is kg*cm^2. Will get it corrected at all the places. Thank you again for reporting the issue.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
