That's what I said, there's very little API support for CAM, so it's not possible to automate the creation of the tool path you need, regardless of which language you're using.
If it does turn out that you need points, one other option is to create the model using the temporary B-Rep approach and then also create a new sketch and create all of the needed points in it. That should also be relatively fast, especially if you use the Sketch.isComputeDeferred property.
Brian EkinsInventor and Fusion 360 API Expert
Website/Blog:
https://EkinsSolutions.com
