Trying to pause 'for' loop
brad.bylls
brad.bylls
Going through a for loop and wanting to pause for user input.
for plate in range(1, len(plates)):
    tablePlate = inputs.addStringValueInput('tablePlate', '', plates[plate])
    tablePlate.isReadOnly = True
    table.addCommandInput(tablePlate, plate + 1, 0, 0, 0)
    tableInput = inputs.addStringValueInput('partNum', 'Part Number', '')
    table.addCommandInput(tableInput, plate + 1, 2, 0, 0)
    tableInput = inputs.addStringValueInput('partName', 'Part Name', '')
    table.addCommandInput(tableInput, plate + 1, 3, 0, 0)
    waitBox = input("Fill in the " + tablePlate.value + " info, then press ENTER")
When I get to the end I get this error message.
tablePlate.value is string.
Brad Bylls
jeff.pek
Hi Brad -
The input method will return what the user entered. It will not fill in the value you placed into the string. So, I think you'd want to do:
userResponse = input("...")
# Do something with response
Jeff
brad.bylls
That does not work'
tablePlate.value would be "CP Plate"
waitBox then equals "Fill in the CP Plate info, then press ENTER" if my syntax is correct.
There are input boxes in a dialog box on the screen that I want the user to fill in before continuing.
That is why I am trying to pause the 'for' loop.
Brad Bylls
Jorge_Jaramillo
You can not use input() function to request data to the user inside Fusion360.
input() is used in scripts that don't have an user interface like in the following screen cast:
In the case of Fusion360, you might want to use the GUI for user input with the set of command objects, like the ones you have in your script.
An additional topic in your script:
start the for loop with the range() call with initial value 0 instead of 1.
Hope this could help.
Jorge Jaramillo
brad.bylls
So there is no way to pause a script inside of Fusion?
As for starting at 0, that data is used elsewhere and not needed on this loop.
Thanks for the input.
Brad Bylls
Jorge_Jaramillo
Yes, you have to set the right command to request input to the user one set of items at a time.
It is tricky since you cannot start a new command inside the on_input_changed(), because the input event has not completed at that moment; you have to use an user event to be fired after it, which will start the new command to request the following set of information.
I'd suggest to make a single command input with all the data you require the user to provide.  This way is easier and straightforward.
Jorge Jaramillo
brad.bylls
Thanks.
I'll try something with that.
Brad Bylls
