Troubleshooting Additive Manufacturing Implementation in Fusion 360 using C++
subhashraj8210
Observer Observer
subhashraj8210
Observer
Observer
I'm exploring additive Manufacturing in fusion 360 using C++. In the fusion's documentation I got a sample program in Python as below -
import adsk.core, adsk.fusion, adsk.cam, traceback, tempfile, time
from . import commands
from .lib import fusion360utils as futil
app = adsk.core.Application.get()
ui  = app.userInterface
def showMessage(message):
    app.log(message)
# Create an additive setup.
def createAdditiveSetup(models: list[adsk.fusion.Occurrence], cam: adsk.cam.CAM):
    setups = cam.setups
    input = setups.createInput(adsk.cam.OperationTypes.AdditiveOperation)
    input.models = models
    input.name = 'AdditiveSetup'
    camManager = adsk.cam.CAMManager.get()
    libraryManager = camManager.libraryManager
    printSettingLibrary = libraryManager.printSettingLibrary
    machineLibrary = libraryManager.machineLibrary
    printSetting = None
    machine = None
    if True:
        # URL-structure browsing
        printSettingUrl = printSettingLibrary.urlByLocation(adsk.cam.LibraryLocations.Fusion360LibraryLocation) ## .Fusion360LibraryLocation vs .LocalLibraryLocation etc.
        printSettings = printSettingLibrary.childPrintSettings(printSettingUrl)
        machineUrl = machineLibrary.urlByLocation(adsk.cam.LibraryLocations.Fusion360LibraryLocation) ## .Fusion360LibraryLocation vs .LocalLibraryLocation etc.
        machines = machineLibrary.childMachines(machineUrl)
        for ps in printSettings:
            if ps.name ==  "PLA (Direct Drive)": #print setting name from fusions library
                printSetting = ps
                break
        for machine in machines: #model name from fusions library -- Example: "Generic FFF Machine"
            if machine.model ==  "i3 MK3S+":
                machine = machine
                break
    input.machine = machine
    input.printSetting= printSetting
    setup = setups.add(input)
    return setup
# Given an occurrence, this finds all child occurrences that contain either a
# B-Rep or Mesh body. It is recursive, so it will find all occurrences at all levels.
def getValidOccurrences(occurrence: adsk.fusion.Occurrence) -> list[adsk.fusion.Occurrence]:
    result = []
    for childOcc in occurrence.childOccurrences:
        if (childOcc.bRepBodies.count + childOcc.component.meshBodies.count  > 0):
            result.append(childOcc)
        result.extend(getValidOccurrences(childOcc))
    return result
def run(context):
    try:
        # This will run the start function in each of your commands as defined in commands/__init__.py
        #commands.start()
        # Make sure the TEXT COMMAND palette is visible.
        textPalette = ui.palettes.itemById('TextCommands')
        if not textPalette.isVisible:
            textPalette.isVisible = True
            adsk.doEvents()
        doc = app.activeDocument
        products = doc.products
        # Make
        camWS = ui.workspaces.itemById('CAMEnvironment')
        camWS.activate()
        cam = adsk.cam.CAM.cast(products.itemByProductType("CAMProductType"))
        # Design creation
        designWS = ui.workspaces.itemById('FusionSolidEnvironment')
        designWS.activate()
        design = adsk.fusion.Design.cast(products.itemByProductType("DesignProductType"))
        camWS.activate()
        showMessage('=============================================')
        showMessage('Creating Manufacturing Model...')
        manufacturingModels = cam.manufacturingModels
        mmInput = manufacturingModels.createInput()
        mmInput.name = "My Manufacturing Model - FFF"
        manufacturingModel = manufacturingModels.add(mmInput)
        showMessage('Getting occurrences...')
        occs = getValidOccurrences(manufacturingModel.occurrence)
        if len(occs) == 0:
            ui.messageBox('No component has been added to the scene.')
            return
        showMessage('Creating arrange operation...')
        setup = createAdditiveSetup(occs, cam)
        # Define and create the arrange operation.
        operationInput = setup.operations.createInput('additive_arrange')
        arrange = setup.operations.add(operationInput)
        parameter: adsk.cam.StringParameterValue = arrange.parameters.itemByName("arrange_arrangement_type").value
        parameter.value = 'Pack2D'
        # Specify the values to control the arrangement. All length units are centimeters.
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_platform_clearance").value
        parameter.value = 0
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_frame_width").value
        parameter.value = 0.5
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_ceiling_clearance").value
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_object_spacing").value
        parameter.value = 1
        future = cam.generateToolpath(arrange)
        while (future.isGenerationCompleted == False):
            time.sleep(0.5)
        # Create the automatic orientation operations for each occurrence.
        for occ in occs:
            showMessage(f'Defining orientation for occurrence "{occ.name}" ...')
            operationInput = setup.operations.createInput('automatic_orientation')
            #operationInput.isAutoCalculating = False
            orientationTarget = operationInput.parameters.itemByName('optimizeOrientationTarget')
            orientationTarget.value.value = [occ]
            operationInput.displayName = 'Automatic Orientation: ' + occ.name
            #global orientation
            orientation = setup.operations.add(operationInput)
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationSmallestRotation").value
            parameter.value = 180 #angle units are always degrees
            parameter: adsk.cam.BooleanParameterValue = orientation.parameters.itemByName("optimizeOrientationUsePreciseCalculation").value
            parameter.value = True #capitilize
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationCriticalAngle").value
            parameter.value = 45 #angle units are always degrees
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationDistanceToPlatform").value
            parameter.value = 0 #units are always cm
            parameter: adsk.cam.BooleanParameterValue = orientation.parameters.itemByName("optimizeOrientationMoveToCenter").value
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationFrameWidth").value
            parameter.value = 0.5 #units are always cm
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationCeilingClearance").value
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingSupportVolume").value
            parameter.value = '10' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingSupportArea").value
            parameter.value = '0' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingBoundingBoxVolume").value
            parameter.value = '2' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingPartHeight").value
            parameter.value = '6' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingCOGHeight").value
            showMessage('Generating orientation...')
            future = cam.generateToolpath(orientation)
                time.sleep(0.5)
            generatedResults = orientation.generatedDataCollection
            castPref = None
            firstResult = None
            primary = generatedResults.itemByIdentifier(adsk.cam.GeneratedDataType.OptimizedOrientationGeneratedDataType)
            if isinstance(primary, adsk.cam.OptimizedOrientationResults):
                castPref: adsk.cam.OptimizedOrientationResults = primary
                firstResult = castPref.item(0)
            castPref.currentOrientationResult = firstResult
            showMessage('Generating arrange...')
                time.sleep(0.5)
            showMessage('Generating supports...')
            supportInput = setup.operations.createInput('solid_volume_support')
            volumeSupport = setup.operations.add(supportInput)
            supportParam = volumeSupport.parameters.itemByName('supportTarget')
            supportParam.value.value = occs
            future = cam.generateToolpath(volumeSupport)
                time.sleep(0.5)
            if volumeSupport.hasError:
                volumeSupport.deleteMe()
            showMessage('Generating toolpath...')
            toolpath = None
            i = 0
            for i in range(setup.operations.count):
                op = setup.operations.item(i)
                if (op.strategy == 'additive_buildstyle'):
                    toolpath = op
                    break
            if (toolpath == None):
                return
            future = cam.generateToolpath(toolpath)
                time.sleep(1.0)
            app.activeViewport.fit()
            # Start the toolpath simulation command.
            # app.executeTextCommand('NaNeuCAMUI.AdditiveSimulateCmd')
            showMessage('Finished.')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
        adsk.terminate()
        futil.handle_error('run')
        # end
def stop(context):
    try:
        # Remove all of the event handlers your app has created
        futil.clear_handlers()
        commands.stop()
    except:
        futil.handle_error('stop')
I changed these code in c++ as below -
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
#include <Cam/CamAll.h>
#include <vector>
#include <iostream>
#include <string>
#include <thread>
#define M_PI 3.14
using namespace adsk::core;
using namespace adsk::fusion;
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
/* Create Additive setup*/
Ptr<Setup> createAdditiveSetup(std::vector<Ptr<Occurrence>> models, Ptr<CAM>& cam) {
    Ptr<Setups> setups = cam->setups();
    Ptr<SetupInput> setupInput = setups->createInput(OperationTypes::AdditiveOperation);
    std::vector<Ptr<Base>> _models;
    for (size_t i = 0; i < models.size(); ++i) {
        Ptr<Occurrence> item = models[i];
        Ptr<Base> _occur = item->cast<Base>();
        if (!_occur) {
            ui->messageBox("occurrence is not type cast into Base !");
            return false;
        _models.push_back(_occur);
    bool modelsFlag = setupInput->models(_models);
    if (modelsFlag == false)
        ui->messageBox("Models are not setup into setupInput");
    setupInput->name("AdditiveSetup");
    Ptr<CAMManager> camManager = CAMManager::get();
    Ptr<CAMLibraryManager> libraryManager = camManager->libraryManager();
    Ptr<PrintSettingLibrary> printSettingLibrary = libraryManager->printSettingLibrary();
    Ptr<MachineLibrary> machineLibrary = libraryManager->machineLibrary();
    Ptr<PrintSetting> printSetting = nullptr;
    Ptr<Machine> machine = nullptr;
    /* finding the desired print setting and machine */
    Ptr<URL> printSettingUrl = printSettingLibrary->urlByLocation(LibraryLocations::Fusion360LibraryLocation);
    std::vector<Ptr<PrintSetting>> printSettings = printSettingLibrary->childPrintSettings(printSettingUrl);
    Ptr<URL> machineUrl = machineLibrary->urlByLocation(LibraryLocations::Fusion360LibraryLocation);
    std::vector<Ptr<Machine>> machines = machineLibrary->childMachines(machineUrl);
    for (auto ps : printSettings) {
        if (ps->name() == "PLA (Direct Drive)") {
            printSetting = ps;
            break;
    for (auto mach : machines) {
        if (mach->model() == "i3 MK3S+") {
            machine = mach;
            break;
    setupInput->machine(machine);
    setupInput->printSetting(printSetting);
    Ptr<Setup> setup = setups->add(setupInput);
    return setup;
std::vector<Ptr<Occurrence>> getValidOccurrences(Ptr<Occurrence> occurrence) {
    std::vector<Ptr<Occurrence>> result;
    // Iterate through child occurrences
    Ptr<OccurrenceList> childOccurrences = occurrence->childOccurrences();
    for (size_t i = 0; i < childOccurrences->count(); ++i) {
        Ptr<Occurrence> childOccurrence = childOccurrences->item(i);
        // Check if the child occurrence has valid bodies
        if (childOccurrence->bRepBodies()->count() + childOccurrence->component()->meshBodies()->count() > 0) {
            result.push_back(childOccurrence);
        // Recursively call the function for nested occurrences
        std::vector<Ptr<Occurrence>> nestedOccurrences = getValidOccurrences(childOccurrence);
        result.insert(result.end(), nestedOccurrences.begin(), nestedOccurrences.end());
    return result;
extern "C" XI_EXPORT bool run(const char* context)
    app = Application::get();
    if (!app)
        return false;
    ui = app->userInterface();
    if (!ui)
        return false;
    // get current document
    Ptr<Document> doc = app->activeDocument();
    Ptr<Products> products = doc->products();
    // switch to the manufacture space
    Ptr<Workspace> camWS = ui->workspaces()->itemById("CAMEnvironment");
    camWS->activate();
    // get the CAM product
    Ptr<CAM> cam = products->itemByProductType("CAMProductType")->cast<CAM>();
    // Design creation
    Ptr<Workspace> designWS = ui->workspaces()->itemById("FusionSolidEnvironment");
    designWS->activate();
    Ptr<Design> design = products->itemByProductType("DesignProductType")->cast<Design>();
    camWS->activate();
    // creating Manufacturing Model...
    Ptr<ManufacturingModels> manufacturingModels = cam->manufacturingModels();
    Ptr< ManufacturingModelInput> mmInput = manufacturingModels->createInput();
    mmInput->name("My Manufacturing Model - FFF");
    Ptr<ManufacturingModel> manufacturingModel = manufacturingModels->add(mmInput);
    /* getting occurence */
    std::vector<Ptr<Occurrence>> occs = getValidOccurrences(manufacturingModel->occurrence());
    if (occs.size() == 0) {
        ui->messageBox("No component has been added to the scene");
        return true;
    /* Creating arrange operation....*/
    Ptr<Setup> setup = createAdditiveSetup(occs, cam);
    /* define and create the arrange operation*/
    Ptr<OperationInput> operationInput = setup->operations()->createInput("additive_arrange");
    Ptr<Operation> arrange = setup->operations()->add(operationInput);
    Ptr<ChoiceParameterValue> stringparameter = arrange->parameters()->itemByName("arrange_arrangement_type")->value()->cast<ChoiceParameterValue>();
    if(stringparameter != nullptr)
        if (!stringparameter->value("Pack2D")) {
            ui->messageBox("arrange_arrangement_type failed");
            return true;
    Ptr<FloatParameterValue> floatParameter = arrange->parameters()->itemByName("arrange_platform_clearance")->value()->cast<FloatParameterValue>();
    if(floatParameter != nullptr)
        if (!floatParameter->value(0)) {
            ui->messageBox("arrange_platform_clearance failed !");
            return true;
    Ptr<FloatParameterValue> floatParameter2 = arrange->parameters()->itemByName("arrange_frame_width")->value()->cast<FloatParameterValue>();
    if(floatParameter2 != nullptr)
        if (!floatParameter2->value(0.5)) {
            ui->messageBox("arrange_frame_width failed !");
            return true;
    Ptr<FloatParameterValue> floatParameter3 = arrange->parameters()->itemByName("arrange_ceiling_clearance")->value()->cast<FloatParameterValue>();
    if (floatParameter3 != nullptr)
        if (!floatParameter->value(0.5)) {
            ui->messageBox("arrange_ceiling_clearance failed !");
            return true;
    Ptr<FloatParameterValue> floatParameter4 = arrange->parameters()->itemByName("arrange_object_spacing")->value()->cast<FloatParameterValue>();
    if(floatParameter4 != nullptr)
        if (!floatParameter->value(1)) {
            ui->messageBox("arrange_object_spacing failed !");
            return true;
    Ptr<GenerateToolpathFuture> future = cam->generateToolpath(arrange);
    while (future->isGenerationCompleted() == false)
        std::this_thread::sleep_for(std::chrono::milliseconds(500));
    /*create the automatic orientation operations for each occurrence*/
    for (Ptr<Occurrence> occ : occs) {
        operationInput = setup->operations()->createInput("automatic_orientation");
        //operationInput->isAutoCalculating(false);
        Ptr<CAMParameter> orientationTarget = operationInput->parameters()->itemByName("optimizeOrientationTarget");
        Ptr<CadObjectParameterValue> cadObjectParameterValue = orientationTarget->value()->cast<CadObjectParameterValue>();
        if (!cadObjectParameterValue) {
            ui->messageBox("optimizeOrientationTarget failed !");
            return true;
        //orientationTarget.value.value = [occ]
        std::vector<Ptr<Base>> occurrence;
        Ptr<Occurrence> oc = occ;
        Ptr<Base> item = oc->cast<Base>();
        occurrence.push_back(item);
        if (!cadObjectParameterValue->value(occurrence)) {
            ui->messageBox("Occurrence is not inserted for orientation");
            return true;
        operationInput->displayName("Automatic Orientation: " + occ->name());
        /*global orientation*/
        Ptr<Operation> orientation = setup->operations()->add(operationInput);
        if (orientation != nullptr) {
            Ptr<FloatParameterValue> parameter = orientation->parameters()->itemByName("optimizeOrientationSmallestRotation")->value();
            if (!parameter->value(180)) { // angle units are always degrees
                ui->messageBox("failed for optmize orientation smallest rotation");
            Ptr<BooleanParameterValue> booleanparameter = orientation->parameters()->itemByName("optimizeOrientationUsePreciseCalculation")->value()->cast<BooleanParameterValue>();
            if(booleanparameter != nullptr)
                if (!booleanparameter->value(true)) {
                    ui->messageBox("optimizeOrientationUsePreciseCalculation failed !");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationCriticalAngle")->value()->cast<FloatParameterValue>();
            if (parameter != nullptr)
                if (!parameter->value(45)) {
                    ui->messageBox("optimizeOrientationCriticalAngle failed!");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationDistanceToPlatform")->value()->cast<FloatParameterValue>();
                if (!parameter->value(0)) {
                    ui->messageBox("optimizeOrientationDistanceToPlatform failed !");
                    return true;
            booleanparameter = orientation->parameters()->itemByName("optimizeOrientationMoveToCenter")->value()->cast<BooleanParameterValue>();
            if (booleanparameter != nullptr)
                    ui->messageBox("optimizeOrientationMoveToCenter failed !");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationFrameWidth")->value()->cast<FloatParameterValue>();
                if (!parameter->value(0.5)) {
                    ui->messageBox("optimizeOrientationFrameWidth failed !");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationCeilingClearance")->value()->cast<FloatParameterValue>();
                    ui->messageBox("optimizeOrientationCeilingClearance failed!");
                    return true;
            Ptr<ChoiceParameterValue> choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingSupportVolume")->value()->cast<ChoiceParameterValue>();
            if (choiceParameter != nullptr)
                if (!choiceParameter->value("10")) {
                    ui->messageBox("optimizeOrientationRankingSupportVolume failed !");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingSupportArea")->value()->cast<ChoiceParameterValue>();
                if (!choiceParameter->value("0")) {
                    ui->messageBox("optimizeOrientationRankingSupportArea failed!");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingBoundingBoxVolume")->value()->cast<ChoiceParameterValue>();
                if (!choiceParameter->value("2")) {
                    ui->messageBox("optimizeOrientationRankingBoundingBoxVolume failed !");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingPartHeight")->value()->cast<ChoiceParameterValue>();
                if (!choiceParameter->value("6")) {
                    ui->messageBox("optimizeOrientationRankingPartHeight failed !");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingCOGHeight")->value()->cast<ChoiceParameterValue>();
                    ui->messageBox("optimizeOrientationRankingCOGHeight failed !");
                    return true;
            Ptr<GenerateToolpathFuture> future = cam->generateToolpath(orientation);
            if(future != nullptr)
            Ptr<OptimizedOrientationResult> firstResult = nullptr;
            Ptr<GeneratedDataCollection> generatedResults = orientation->generatedDataCollection();
            Ptr<GeneratedData> primary = generatedResults->itemByIdentifier(GeneratedDataType::OptimizedOrientationGeneratedDataType);
            if (!primary) {
                ui->messageBox("failed !");
                return false;
            if (Ptr<OptimizedOrientationResults> castPref = primary->cast<OptimizedOrientationResults>()) {
                firstResult = castPref->item(0);
                if (!castPref->currentOrientationResult(firstResult)) {
                    ui->messageBox("Optimized Orientation Result failed !");
                    return true;
            // generating support
            Ptr<OperationInput> supportInput = setup->operations()->createInput("solid_volume_support");
            Ptr<Operation> volumeSupport = setup->operations()->add(supportInput);
            Ptr<CAMParameter> supportParameter = volumeSupport->parameters()->itemByName("supportTarget");
            //supportParameter.value.value = occs;
            Ptr<CadObjectParameterValue> _supportParameter = supportParameter->value()->cast<CadObjectParameterValue>();
            std::vector<Ptr<Base>> _occs;
            Ptr<Base> item = occs[0]->cast<Base>();
            if (!item) {
                ui->messageBox("occurrences is not typcast into Base class for support Target !");
                return false;
            if (!item->isValid()) {
                ui->messageBox("occurrence is not valid for supportTarget !");
                return false;
            _occs.push_back(item);
            if (!_supportParameter->value(_occs)) {
                ui->messageBox("Inserting value for support parameter is failed !");
                return true;
            future = cam->generateToolpath(volumeSupport);
            if (volumeSupport->hasError())
                volumeSupport->deleteMe();
        // Generating toolPath
        Ptr<Operation> toolpath = nullptr;
        for (size_t i = 0; i < setup->operations()->count(); ++i) {
            Ptr<Operation> op = setup->operations()->item(i);
            if (op->strategy() == "additive_buildstyle") {
                toolpath = op;
                break;
        if (toolpath == nullptr)
            return false;
        future = cam->generateToolpath(toolpath);
        while (future->isGenerationCompleted() == false) {
            std::this_thread::sleep_for(std::chrono::milliseconds(1000));
        app->activeViewport()->fit();
        // start the toolpath simulation command
        /*app->executeTextCommand("NaNeuCAMUI.AdditiveSimulateCmd");*/
    /// end
    //ui->messageBox("Hello addin");
    return true;
extern "C" XI_EXPORT bool stop(const char* context)
    if (ui)
        ui->messageBox("Stop addin");
        ui = nullptr;
    return true;
#ifdef XI_WIN
#include <windows.h>
BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved)
    switch (reason)
    case DLL_PROCESS_ATTACH:
    case DLL_THREAD_ATTACH:
    case DLL_THREAD_DETACH:
    case DLL_PROCESS_DETACH:
        break;
    return TRUE;
#endif // XI_WIN
In these c++ code, instead of textPalette activation, ui->messageBox() is used.
After the executing these c++ code facing some issue as shown in the below image -
at line no. 333, value(_occs) method returns false. I don't know,  why?
CGBenner
@subhashraj8210
Hello and welcome!  I've moved your post here so that it can be seen by the experts who may best be able to help you.  Good luck!
Chris Benner
