Trouble with batch import and Loft of csv files
Hello everybody,
as the title says I try to import around 200 csv Files in to fusion and then Automatically loft them. As I have not found any script that does a batch import and loft I tried to write my own with limited succes. I managed to import all csv files with modding the importCSV script but I struggle to get them in to a Loft. Here is My Code so far:
#Author-Autodesk Inc.
#Description-Import spline from csv file
import adsk.core, adsk.fusion, traceback
import io
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get all components in the active design.
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent
        title = 'Import Spline csv'
        if not design:
            ui.messageBox('No active Fusion design', title)
            return
        dlg = ui.createFileDialog()
        dlg.title = 'Open CSV File'
        dlg.filter = 'Comma Separated Values (*.csv);;All Files (*.*)'
        if dlg.showOpen() != adsk.core.DialogResults.DialogOK :
            return
        filename = dlg.filename
        for i in range(1,202):#Loop for csv import
         filename = 'C:/*privacy*/layer{}.csv'.format(i)
         with io.open(filename, 'r', encoding='utf-8-sig') as f:
            points = adsk.core.ObjectCollection.create()
            line = f.readline()
            data = []
            while line:
                pntStrArr = line.split(',')
                for pntStr in pntStrArr:
                    try:
                        data.append(float(pntStr))
                    except:
                        break
                if len(data) >= 3 :
                    point = adsk.core.Point3D.create(data[0], data[1], data[2])
                    points.add(point)
                line = f.readline()
                data.clear()
         if points.count:
            design.rootComponent.sketches.add(design.rootComponent.xYConstructionPlane).sketchCurves.sketchFittedSplines.add(points)
         else:
            ui.messageBox('No valid points', title)
        loftFeats = rootComp.features.loftFeatures
        loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        loftSectionsObj = loftInput.loftSections
        for j in range(0,100):#Loop for selecting the scetch profiles for the loft
         profile = design.rootComponent.sketches.add(rootComp.xYConstructionPlane).profiles.item(j)
         loftSectionsObj.add(profile)
        loftInput.isSolid = False
        # Create loft feature
        loftFeats.add(loftInput)
#design.rootComponent.sketches.add(rootComp.xZConstructionPlane).profiles.item(0)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
 I get the Error message Bad Index parameter at line 63. Does annybody know why that is or knows a script that does what I try to implement?
Have a nice Day and Thanks for any help!
BrianEkins
Is it successfully importing the points and creating the sketches with the splines?  If it is getting that far, the problem is in your where you're getting the profile.  You're creating new sketches rather that getting the profile from the sketches you just made.
I made some modifications to your code but with the csv file am unable to test it.  At the top I'm creating a new list called "sketches".  Later where you were creating the splines, I create the sketch as a separate step step, create the spline, and then add the sketch to the list.  And then a big change to where you're populating the loft sections where I iterate over the sketches that were created and get the first profile from each sketch.
        sketches = []
                line = f.readline()
                data = []
                while line:
                        try:
                        except:
                            break
                    if len(data) >= 3 :
                        points.add(point)
                    line = f.readline()
                    data.clear()
            if points.count:
                sketch = design.rootComponent.sketches.add(design.rootComponent.xYConstructionPlane)
                sketch.sketchCurves.sketchFittedSplines.add(points)
                sketches.append(sketch)
            else:
        for sketch in skethes:
            profile = sketch.profiles.item(0)
Brian Ekins
Thank you it works like a charm!
