Trouble Scaling after copying and moving component.
alfredordz86
alfredordz86
Hi guys, total beginner writing scripts here.
I'm trying to copy, move and rotate a body and then scale the new body in its new position. I didn't have much trobule moving it a few inches in the x axis and rotating it 90 degrees (see screenshot) but I've been stuck for hours trying to scale it. I get RuntimeError: 2 : InternalValidationError : Utils::getObjectPath(obj.get(), objPath, nullptr, path)  (line 80). I'm totally lost here, I'd really appreciate some input.
Thanks!
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        if not design:
            ui.messageBox('No active Fusion design', 'No Design')
            return
        # Get the root component of the active design.
        rootComp = design.rootComponent
        features = rootComp.features
        # Get the first sub component
        occs = rootComp.occurrences
        subComp1 = occs.item(0).component
         # Create sketch
        sketches = rootComp.sketches
        sketch = sketches.add(rootComp.xYConstructionPlane)
        sketchCircles = sketch.sketchCurves.sketchCircles
        centerPoint = adsk.core.Point3D.create(0, 0, 0)
        circle = sketchCircles.addByCenterRadius(centerPoint, 1.5)
        # Get the first body in sub component 1
        baseBody = subComp1.bRepBodies.item(0)
        # Copy/paste bodies
        subComp1.features.copyPasteBodies.add(baseBody)
        # Rename Body
        baseBodyCopy = subComp1.bRepBodies.item(1)
        # Create a collection of entities for move
        bodies = adsk.core.ObjectCollection.create()
        bodies.add(baseBodyCopy)
        # Create a transform to do move
        vector = adsk.core.Vector3D.create(5, 0, 0)
        transform = adsk.core.Matrix3D.create()
        transform.translation = vector
        # Create a move feature
        # moveFeats = features.moveFeatures
        moveFeats = subComp1.features.moveFeatures
        moveFeatureInput = moveFeats.createInput(bodies, transform)
        moveFeats.add(moveFeatureInput)
        # Create a transform to do rotation
        rotPoint= adsk.core.Point3D.create()
        rotPoint = adsk.core.Point3D.create(5, 0, 0)
        transform.setToRotation(3.1416,(rootComp.zConstructionAxis.geometry.getData()[2]),rotPoint)
        inputColl = adsk.core.ObjectCollection.create()
        inputColl.add(baseBody)
        basePt = sketch.sketchPoints.item(0)
        scaleFactor = adsk.core.ValueInput.createByReal(1)
        scales = rootComp.features.scaleFeatures
        scaleInput = scales.createInput(bodies, basePt, scaleFactor)
        #Set the scale to be non-uniform
        xScale = adsk.core.ValueInput.createByReal(1.5)
        yScale = adsk.core.ValueInput.createByReal(3)
        zScale = adsk.core.ValueInput.createByReal(2)
        scaleInput.setToNonUniform(xScale, yScale, zScale)
        scale = scales.add(scaleInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Jorge_Jaramillo
Hi @alfredordz86 ,
The ScaleFeatureInput need to be created with the parent component of the body.
So, in you code replace line 71 with this:
scales = baseBodyCopy.parentComponent.features.scaleFeatures
This solve your problem.
Hope this can help.
Jorge
alfredordz86
Yes!!! I had been stuck for hours with this. I'm still starting to understand how everything works in Python.
Muchas gracias mi estimado Jorge.
