Traceback error
Traceback error
Traceback error
Hello all,
I'm new here.  I just started using fusion.
I want to convert mij model to GBRL using the Add on. Now i get this failure.
Failed:
Traceback(most resent call last):
File *C/User/***/Appdata/Roaming/Autodesk/Autodesk Fusion 360/API/Addins/UGS_Fusion/UGS_Fusion.py*. line 223, in notify
(OpName,UGS_path,UGS_post,UGS_platform,saveSettings,ShowOperations) = getInputs(inputs)
File *C/User/***/Appdata/Roaming/Autodesk/Autodesk Fusion 360/API/Addins/UGS_Fusion/UGS_Fusion.py*. line 190, in getInputs
opName = OperationName
UnboundLocalError:local variable 'operationName' reference before assignment.
BrianEkins
The last line is saying that you are using the variable named operationName before you've assigned it a value.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
brad.bylls
I am having the same exception error except the local variable has a been assigned a value.
You can see that when I hovered over strResult2, it shows a value of '1/2"'
I would think that this has been assigned a value.
But I get the exception error:
strResult2 is assigned a value in the input_changed method where it is also assigned as Global.
The error is coming in the on_execute method.
As you can see in the image above it has an assigned value.
I'm puzzled.
Brad Bylls
