Tiny Addin Crashes Fusion
chrisNS2SW
chrisNS2SW
Opening a sketch, and running this addin crashes Fusion. If you're using the api & transactions, make sure you keep track of your transaction states.
import adsk.core
def run(context):
  app = adsk.core.Application.get()
  app.executeTextCommand(f'Transaction.Commit None')
def stop(context):
  pass
Phil.E
Thanks for this great advice.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
chrisNS2SW
@Phil.E seems like a bug in Fusion that may be worth fixing. What's the best way to report these so they make it in to the bug tracker?
Phil.E
The best way to report issues like this is on this forum, or in the Fusion Insider forums if you want to join that program.
Can you explain a little about why this is important? I'm asking because anyone could write an add-in that crashes Fusion, I'm not sure we need to prevent that. So what does this add-in do, or provide for an add-in author that is risky? I'm just trying to estimate the risk to customers like you.
If you happen to have a crash report number I can also look into the actual crash reports.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
