Threading stops on document change
Joshua.mursic
Joshua.mursic
Hello everyone, I have created a thread to watch a setup so the user can see its generation status even if they are in a different document.
import adsk.core,adsk.fusion,adsk.cam,traceback,threading,time
app = adsk.core.Application.get()
ui = app.userInterface
ACTIVE_THREADS = []
#Monitors a setups progress
class SetupMonitor(threading.Thread):
    def __init__(self, setup:adsk.cam.Setup):
        '''setup is a object collection of setups'''
        threading.Thread.__init__(self)
        global ACTIVE_THREADS
        self.running = True
        self.setup = setup
        self.graphicsGroup = None
        self.createText()
        ACTIVE_THREADS.append(self)
    def createText(self):
        try:
            design:adsk.fusion.Design = app.activeDocument.products.itemByProductType('DesignProductType')
            cam:adsk.cam.CAM = app.activeDocument.products.itemByProductType('CAMProductType')
            root = design.rootComponent
            #get the number of completed operations
            completed = 0
            for operation in self.setup.operations:
                complete = cam.checkToolpath(operation)
                if complete:
                    completed += 1
            #create new graphics group
            graphics = root.customGraphicsGroups.add()
            graphics.isVisible = False
            offset = len(ACTIVE_THREADS)*5
            graphicsText = graphics.addText(f'{self.setup.name}: {completed}/{self.setup.allOperations.count}', 'Arial', 3, adsk.core.Matrix3D.create())
            graphicsText.isBold = True
            graphicsText.color =  adsk.fusion.CustomGraphicsSolidColorEffect.create(adsk.core.Color.create(255,255,255,255))
            billBoard = adsk.fusion.CustomGraphicsBillBoard.create(adsk.core.Point3D.create(0,0,0))
            billBoard.billBoardStyle = adsk.fusion.CustomGraphicsBillBoardStyles.ScreenBillBoardStyle
            graphicsText.billBoarding = billBoard
            #use exsisting or create a new anchor point
            if self.graphicsGroup: #use the exsisting anchor point
                text:adsk.fusion.CustomGraphicsText = self.graphicsGroup.item(0)
                anchorPoint = text.viewPlacement.anchorPoint
                #delete old graphics
                self.graphicsGroup.deleteMe()
            else:
                anchorPoint = adsk.core.Point3D.create(graphicsText.width,graphicsText.height+offset,0)
            # Set the text to use view scaling.
            graphicsText.viewScale = adsk.fusion.CustomGraphicsViewScale.create(4, adsk.core.Point3D.create(0,0,0))
            viewPlace = adsk.fusion.CustomGraphicsViewPlacement.create(anchorPoint,adsk.fusion.ViewCorners.upperRightViewCorner,adsk.core.Point2D.create(10, 80))
            graphicsText.viewPlacement = viewPlace
            self.graphicsGroup = graphics
            graphics.isVisible = True
            app.activeViewport.refresh()
        except:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
    def run(self):
        while self.running:
            toolpathsComplete = cam.checkToolpath(self.setup)
            if toolpathsComplete:
            else:
                #update the progress
                time.sleep(5)
                app.log('working')
                self.createText()
                adsk.doEvents()
    def stop(self):
        app.log("Stopping Thread")
        self.running = False
        ACTIVE_THREADS.remove(self)
The issue I am having is that when the user moves to a different document the threading stops which is unexpected. The threading continues even if you stop the addon that is running it. so i am confused as to why it is stopping on a document change.
The threading class is inside the addons main code, the one with the start() and stop() functions. (I am not sure if this is the correct naming, I am not a coder). So when the command that creates the thread is destroyed, the thread should keep going right?
BrianEkins
I'm not sure exactly what's going on, but I don't believe what you're attempting to do will work. Most of Fusion is single-threaded. There are a few things where Fusion will start background threads to do some computation (like process CAM operations), but they're the exception. The API runs in the single main thread; you can't call it from another thread. A workaround to be able to make calls from another thread is use a Custom Event, which is described here: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F9FD4A6D-C59F-4176-9003-CE04F7558CCC
Brian Ekins
Joshua.mursic
I understand, thank you for the information @BrianEkins. Would the built in setupChanged event trigger when an operation completes its calculation? Are there events for operations?
BrianEkins
Events are fired on the main thread, so your program can listen for them and make API calls in reaction. I don't believe there are events for operations yet. Exposing events is tricky because they need to be fired when it's safe for the client to use the API.
Brian Ekins
Joshua.mursic
Thank you for your help
