The result of setByDistanceOnPath varies depending on the mode
kandennti
Mentor Mentor
kandennti
Hi there.
I created a plane using the "ConstructionPlaneInput.setByDistanceOnPath" method and noticed that the planes created in parametric mode and direct mode are different.
I created a script like this to test it.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        msg: str = 'Select Edge'
        selFilter: str = 'Edges'
        sel: adsk.core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        edge: adsk.fusion.BRepEdge = sel.entity
        comp: adsk.fusion.Component = edge.body.parentComponent
        valueIpts = [
            adsk.core.ValueInput.createByReal(0),
            adsk.core.ValueInput.createByReal(0.5),
            adsk.core.ValueInput.createByReal(1),
        constPlanes: adsk.fusion.ConstructionPlanes = comp.constructionPlanes
        for valueIpt in valueIpts:
            planeIpt: adsk.fusion.ConstructionPlaneInput = constPlanes.createInput()
            planeIpt.setByDistanceOnPath(edge, valueIpt)
            constPlanes.add(planeIpt)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectEnt(
        msg: str,
        filterStr: str) -> adsk.core.Selection:
    try:
        ui: adsk.core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
Creates three planes with ratios of 0, 0.5, and 1 for the selected edge.
Prepare a body, which can be anything, run the script and select an edge.
If you select the red arrow in the left image, a plane is created in parametric mode, as shown in the middle image. This is the desired state, no problem.
In direct mode, however, the image on the right shows the situation.
The same is true for the parametric mode BaseFeature edit.
In direct mode, I think the "distance" argument is treated as a numerical value of a parameter on the curve.
However, when I try to set the value of a parameter to the "distance" argument, I sometimes get an error because of the limitation of 0 to 1.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-46dd5f0a-e384-4707-b431-37c0e596f328
In any case, there is no way to create the desired plane in direct mode.
BrianEkins
I can reproduce the behavior and will see that a bug is logged.
I see that in the UI, the command supports specifying the distance by "Proportional" or "Distance". I think the "Distance" option is new since this API was implemented. I was guessing that the API was using the distance in direct modeling, but that doesn't appear to be the case.
Brian Ekins
kandennti
@BrianEkins Thanks for the reply.
As for the direct mode, it is not used very often, so there may be something else.
kandennti
I came up with a workaround.
When in direct mode, I found that I could temporarily switch to parametric mode to create a plane at the desired position.
import traceback
import adsk.fusion
import adsk.core
DESIGN_TYPES = adsk.fusion.DesignTypes
def run(context):
    try:
        if not sel:
            return
        valueIpts = [
        des: adsk.fusion.Design = app.activeProduct
        returnDesignType = False
        if des.designType == DESIGN_TYPES.DirectDesignType:
            returnDesignType = True
            token = edge.entityToken
            des.designType = DESIGN_TYPES.ParametricDesignType
            edge = des.findEntityByToken(token)[0]
        if returnDesignType:
            des.designType = DESIGN_TYPES.DirectDesignType
    except:
        if ui:
def selectEnt(
        msg: str,
    try:
        return sel
    except:
        return None
I think parametric -> direct -> parametric would be a problem, but I don't think direct -> parametric -> direct would be a problem.
