The latest Fusion update has removed the ValidateInputsEvent
balunist
Message 1 of 15
balunist
The ValidateInputsEvent which is used to validate user input and enable OK selection is missing?   All my add-ins no longer work without this event.
Replies (14)
Message 2 of 15
balunist
Here is a summary:
Fusion Version.         ValidateInputEvent
Win - 2.0.8809           Yes
Win - 2.0.8950           No
Mac - 2.0.8809          Yes
Mac - 2.0.8950           No
My add-ins depend on the event to check if the current state of the inputs are valid and prepare for execution.
I've confirmed my event handler is being added without error it is just not being called.
I find it hard to believe that other add-ins are not seeing this.   Could someone please confirm.
Thanks in advance!
Icarus
Message 3 of 15
prainsberry
I just did a quick test and I believe I am seeing the same thing.  Let me do some more investigation with the team and will get back shortly.
Patrick Rainsberry
Developer Advocate, Fusion 360
Message 4 of 15
navid.nikbin
Recently I have encountered the same problem in my add-ins
Message 5 of 15
navid.nikbin
I hope Autodesk solves the issue as soon as possible, because I it seems to be a critical bug and many add-ins may depend on it to function properly.
Message 6 of 15
grazvydas
Same there. Half functions of our add-in do not work and Fusion crashes.
Message 7 of 15
obatake5TC3R
I have confirmed that ValidateInputsEventHandler has not been called.If it is a specification change, a major program change is required.Please do something about it.
Message 8 of 15
prainsberry
Thank you for reporting the issue.  The team found the issue and a fix has been implemented.  We will try to get this out in a Fusion hotfix as soon as possible.   There is a bit of a process here, please bear I'll update this thread with details as soon as I have a date.
In the meantime if you are really jammed up is it possible maybe to move that logic into an inputChanged event?  Not ideal, I know, but for the short term?
Patrick Rainsberry
Message 9 of 15
balunist
Patrick,
Thanks for the quick response to you and the team.   Your suggested modification is really not feasible for several reasons.   It's a big enough change to require a large amount of validation and testing (time).   Secondly, to get an update through the app store and available to my customers is typically a week's time.   So the best approach is to restore this function with an update from Fusion as quickly as possible.
I will add that in the 3 years that I have been involved with Fusion that there has been very few mishaps giving the frequency of the updates.   But given the severity for this issue it does warrant an additional test case to the test suit run with each release.
Thanks again!
Icarus
Message 10 of 15
grazvydas
How long it could take till the update will be released? (week, two or month?).
Message 11 of 15
prainsberry
We are currently targeting a deployment for early next week (September 22 likely). The validateInputs issue should be fixed in that release.  If anything changes i will be sure to update this thread.
I want to sincerely apologize for the challenges this has caused.  As a result of this issue we have committed yesterday to make a large overhaul of the testing and validation processes we have for the API.
Patrick Rainsberry
Message 12 of 15
balunist
Patrick,
Great news on both accounts.   The enhanced testing puts a positive spin on things.   btw, I did take your suggestion and provided a workaround just in case things do slip.
Thanks again!
Icarus
Message 13 of 15
marcinszydlowski.1984
Hello @prainsberry
Is September 22 still actual?
Message 14 of 15
prainsberry
Hey I just checked and it looks like the update should start rolling out in the next couple hours.
Patrick Rainsberry
Message 15 of 15
Ok, thank @prainsberry for the confirmation.
