The Autodesk Fusion 360 dependency DLL files are not present in the installed path
Itsautodesklicense3
Message 1 of 8
Itsautodesklicense3
We are trying to open a file in the Fusion 360 application using our C# library. For this, we need to reference Autodesk.Fusion360.Addin, Autodesk.Fusion360.Core, Autodesk.Fusion360.Document and Autodesk.Fusion360.Application. However, we are unable to find these DLLs in the installed path. How can we reference the necessary DLLs?
Replies (7)
Message 2 of 8
RajkumarIlanchelian
@Itsautodesklicense3 Checking with our development team on this.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 8
RajkumarIlanchelian
@Itsautodesklicense3 Checking with the team if you are writing an add-in the recommendation is to use C++ or Python (https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A92A4B10-3781-4925-94C6-47DA85A4F65A) and these are the programs that will give you all the access you need.
Autodesk Fusion
Join Fusion Insider
Message 4 of 8
Itsautodesklicense3
Hi Autodesk Team,
We are developing an add-in using C++ but haven’t found any sample code for opening, saving, and closing file. Ultimately, we intend to use the C++ plugin from C# code. Could you please provide us with sample code to communicate with Fusion 360 from C# to perform these operations using the add-in?
Message 5 of 8
jeff.pek
@Itsautodesklicense3 - In order to be able to use C# as part of add-in, you would need to have a bridge project in C++/CLI. This bridge project would communicate with the C++ API in Fusion, and with the C#. See this article. You can't communicate directly to the Fusion API from C#.
Jeff
Message 6 of 8
Itsautodesklicense3
@jeff.pek, You mentioned some article to read, but I don’t see the link. Could you please add it? Also, if possible, could you provide sample code links for opening, saving, and closing file from c++? Thanks
Message 7 of 8
jeff.pek
Message 8 of 8
jeff.pek
There are lots of samples, in both C++ and Python, on the Fusion API Help pages.
  Jeff
