Spyder error
Spyder error
copypastestd
Message 1 of 9
Spyder error
copypastestd
I got errors in Spyder, when I tried to run script from Spyder (and nothing happends in Fusion design window)
But the same script works fine when I run it from Fusion 360.
Replies (8)
Message 2 of 9
marshaltu
Unfortunately I cannot reproduce the issue in my machine. I would like to get more information to diagnose the issue. Was it script-specific issue? Please try to debug other scripts(e.g. TestScript) in Spyder and see if it works or not. If it was script-specific issue, it would be great if you can share a copy to me(marshal dot tu at autodesk dot com).
Marshal
Marshal Tu
Fusion Developer
Message 3 of 9
copypastestd
Marshal, check my screencast, plz - http://autode.sk/2shwTxr
And my code you could find there - https://github.com/PhilippNox/NiceBox-360
Message 4 of 9
marshaltu
I downloaded your script and gave a try according to the steps in the screencast. Unfortunately it cannot be reproduced in my machine (Fusion 360 2.0.3173 + Spyder 2.3.2).
Could you please tell me your Fusion 360 and Spyder versions? Or please try to uninstall Fusion and reinstall the latest version and see if the issue is still reproducible?
Marshal
Marshal Tu
Fusion Developer
Message 5 of 9
copypastestd
I have thr same versions.
Reinstall Fusion is not a big deal.
But I don't know how to reinstall Spyder properly, because I don't see it in installed programs on my computer.
Message 6 of 9
marshaltu
There is no separate entry for Spyder. Uninstalling Fusion 360 will help uninstall Spyder. After reinstalling Fusion 360, Spyder will not be installed initially and you can trigger to install it by editting or debugging Python scripts.
Marshal
Marshal Tu
Fusion Developer
Message 7 of 9
copypastestd
I reinstalled Fusion 360 - but result is the same, I got exactly the same errors.
Message 8 of 9
marshaltu
Thank you for your patience.
I have to collect more information from you to diagnose the issue.
1. Could you send me the detailed callstack for the issue? The snapshot your posted was just trimmed.
2. Please check if there is a folder named ".spyder2-py3" under "C:\Users\<user>\" in your side? If yes, please try to delete the folder and see if it makes any difference.
    From the partial callstack, something was wrong during loading history. But it worked well in my side.
Marshal
Marshal Tu
Fusion Developer
Message 9 of 9
copypastestd
Tnx, Marshal last advice was successfull.
I deleted that folder, and now my Spyder works fine.
After that Spyder just recreated that deleted folder.
