Spline/Points using spreadsheet to parametric update of spline/points
Felipe.G
Felipe.G
Is there an app that can "control" splines or points with an spreadsheet?, we can import splines/points, but I would like to be able to keep the data connected to a spreadsheet, so i can change the coordinates on the spreadsheet and update the splines/point on the drawing
Thank you for the help
OceanHydroAU
Did you work this out in the end?
The new entityToken feature along with attributes will be your key to getting that to work.
If you're doing things like propellers (your logo icon suggests maybe?) my airfoil tools add-in supports importing and exporting spreadsheets along with setting attributes and entityTokens - so it's 90% of the way there.
