insertFromDataPanel Event
hawx75
hawx75
Is there a way to get an event for when the user inserts a design from the data panel similar to the Application.insertedFromUrl event?
kandennti
Hi @hawx75 .
When I tried it, an event was triggered when I inserted the design from the data panel.
Using UserInterface.commandStarting Event, it was made to react only to FusionImportCommand.
#Fusion360API python addin
import adsk.core, adsk.fusion, traceback
handlers = []
class MyImportStartingHandler(adsk.core.ApplicationCommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        eventArgs = adsk.core.ApplicationCommandEventArgs.cast(args)
        ui  = eventArgs.firingEvent.sender
        if ui.activeCommand != 'FusionImportCommand':
            return
        ui.messageBox('Import Starting Event')
def run(context):
    ui = None
    try:
        app :adsk.core.Application = adsk.core.Application.get()
        ui  = app.userInterface
        onImportStarting = MyImportStartingHandler()
        ui.commandStarting.add(onImportStarting)
        handlers.append(onImportStarting)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui.messageBox('Stop addin')
    except:
        if ui:
Since we have only performed simple tests, there may be some problems.
hawx75
Thank you very much. You have also help me discover the huge amount of events that I can use. Never thought to print out UserInterface.commandDefinitions, it seems so obvious now.
hawx75
@kandennti
Is it possible to get the occurrence? It looks as if this event is triggered at the beginning of the import and so there doesn't seem to be a reference to an occurrence. I also tried using UserInterface.commandTerminated again no reference to an occurrence.
kandennti
I also tried with commandTerminated.
When using messageBox, it became impossible to debug, and it was very difficult.
_handlers = []
_occs = []
_app = adsk.core.Application.cast(None)
class MyFileImportHandler(adsk.core.ApplicationCommandEventHandler):
    def __init__(self):
        super().__init__()
        ui  = _app.userInterface
        cmdIdPair = '{}:{}'.format(ui.activeCommand,eventArgs.commandDefinition.id)
        # print('^^^' + cmdIdPair) #debug
        # self.dump_occs() #debug
        if cmdIdPair == 'SelectCommand:ContinueDragFromDashboardCommand':
            self.getOccs()
        elif cmdIdPair == ':CommitCommand':
            self.getInsertOccs()
    def getOccs(self):
        occs = _app.activeProduct.rootComponent.allOccurrences
        global _occs
        _occs = list([occ.name for occ in occs])
    def getInsertOccs(self):
        tmp = list([occ.name for occ in occs])
        global _occs
        insertOccs = set(tmp) - set(_occs)
        _occs = tmp.copy()
        # Do not use messageBox. Debugging will not work.
        # If you do, [Preferences]-[API]-[debugging Port]
        # Please change the value of. ↓
        # _app.ui.messageBox('\n'.join(insertOccs))
        print('-- insert Occ Name --')
        print('\n'.join(insertOccs))
    # debug
    def dump_occs(self):
        print([occ.name for occ in occs])
def run(context):
    ui = None
    try:
        global _app, _occs
        _app = adsk.core.Application.get()
        _occs = []
        onImportStarting = MyFileImportHandler()
        ui.commandTerminated.add(onImportStarting)
        _handlers.append(onImportStarting)
        ui.messageBox('Start addin')
    except:
        if ui:
def stop(context):
    ui = None
    try:
    except:
        if ui:
I realized later that using Application.registerCustomEvent might be the right thing to do.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-85edd118-c2a4-11e6-b401-3417ebc87622
hawx75
Thank @kandennti, your a legend!
