Solid Model to Tool Holder Error Message
jonathanBUCVS
jonathanBUCVS
Using the script linked from NYCCNC/George Roberts https://www.nyccnc.com/solid-model-to-tool-holder/
Getting the error message attached. Other 3d files from the same mfg work ok. Any suggestions?
kandennti
Hi @jonathanBUCVS .
I gave it a try.
It seems to work in direct mode (no timeline).
It would be better to contact the developer directly.
jonathanBUCVS
@kandennti  Thank you, deleting the design history worked. Any idea why the design history was causing an error? I would never have thought to change that.
kandennti
It was described in the document setByPlane Method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-0617e8da-d860-4a39-be2b-27ab2e223a53
Probably during development, you would have tried it with Step files, etc.
If you import a file that is not in native format, it will be in direct mode, so I guess I missed it.
gtprototype
I can't seem to get the script to work.  I have no idea what I'm doing, I followed the video by NYC-CNC.  Although probably not relevant, it appears that the script has been edited to include a pop up instructional screen and a file name input field.  The error message I receive is below.  Any help would be greatly appreciated.  Thank you.
Failed:
Traceback (most recent call last):
File "C:/Users/dale/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/holderCreatorNEW-1.py", line 167, in run
filename = createHolder()
File "C:/Users/dale/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/holderCreatorNEW-1.py", line 134, in createHolder
with open(filename, 'w+') as f:
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Users\\dale\\Downloads\\04-0045 v2.json'
Dale Speakes
prototype technology
