SketchLine.midSketchPoint property?
Message 1 of 10
I can get a SketchPoint for the start and end of a SketchLine with the startSketchPoint and endSketchPoint properties.
I would like to draw a new line and specify one end to be at the centre of an existing line.
I was expecting to be able to use something like a midSketchPoint property of the existing line but it seems this doesn't exist.
What is the easiest way to create a SketchPoint at the centre of an existing SketchLine?
Replies (9)
Message 2 of 10
MichaelT_123
Mr. DaHouseCat,
Take  line.startPoint.geometry and line.endPoint.geometry.
Take averages of their respective coordinates e.g. x_ave = (x_sP + x_eP)/2
Create based on them the new Point3D and a corresponding sketch point (directly or indirectly by the creation of a new line).
Good Luck
MichaelT
MichaelT
Message 3 of 10
Hi MichaelT,
Yes of course. Thanks for the pointer.
This fuction ended up working great for me:
def lineMidPoint(sketchLine):
    sx = sketchLine.startSketchPoint.worldGeometry.x
    sy = sketchLine.startSketchPoint.worldGeometry.y
    sz = sketchLine.startSketchPoint.worldGeometry.z
    ex = sketchLine.endSketchPoint.worldGeometry.x
    ey = sketchLine.endSketchPoint.worldGeometry.y
    ez = sketchLine.endSketchPoint.worldGeometry.z
    ax = (sx + ex) / 2
    ay = (sy + ey) / 2
    az = (sz + ez) / 2
    return adsk.core.Point3D.create(ax, ay, az)
Message 4 of 10
MichaelT_123
Perfect DaHouseCat,
You might consider, however:
- If you know that the line is 2D you can omit z coordinate as it will always be 0.
- if you just dealing with the sketch without considering broader design context geometry instead wordGeometry would be sufficient. It is supposedly cheaper.
- If you want some a little bit more advanced way to do the same, look at curve evaluator functionality.
  It might be overkill in this case though.
Regards
MichaelT
MichaelT
Message 5 of 10
BrianEkins
To get the same result as when sketching in the user-interface and so your line will remain connected to the center of the other line if you make changes, you can use the midpoint constraint. Something like the code below.  The initial position of the second point of line2 doesn't matter because it will get repositioned when the constraint is added.
pnt1 = adsk.core.Point3D.create(0,0,0)
pnt2 = adsk.core.Point3D.create(8,9,0)
line1 = lines.addByTwoPoints(pnt1, pnt2)
pnt3 = adsk.core.Point3D.create(0,5,0)
pnt4 = adsk.core.Point3D.create(4,4,0)
line2 = lines.addByTwoPoints(pnt3, pnt4)
sk.geometryConstraints.addMidPoint(line2.endSketchPooint, line1)
Brian Ekins
Message 6 of 10
MichaelT_123
Hi Mr. Ekins,
This is exquisite and in many circumstances handy way...
It might be useful to note that 'the direct' and 'the constrained' method are not 1:1 equivalent.
The difference is in the final relations (constrained or not) of created lines and as such subject of design intentions.
With Regards
MichaelT
MichaelT
Message 7 of 10
Mr. Brian Ekins -
I entered this script, and it creates the 2 lines, but it gives an error on the line that creates the midpoint constraint.
Can you test the script I pasted below and see if you get the same error, and if you can tell what the problem is?  I tried it on both Mac and Windows and get the same error in both places.
Here is the exact code I am running (made some tweaks to turn it into a full ready-to-run script):
#Author- sample from Fusion API forum by Brian Ekins
#Description-midpoint constraint https://forums.autodesk.com/t5/fusion-360-api-and-scripts/sketchline-midsketchpoint-property/td-p/8453832
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        #des = adsk.fusion.Design.cast(app.activeProduct)
        #root = des.rootComponent
        drawLinesWithMidpointContraint()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def createNewComponent():
    # Get the active design.
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    rootComp = design.rootComponent
    allOccs = rootComp.occurrences
    newOcc = allOccs.addNewComponent(adsk.core.Matrix3D.create())
    return newOcc.component
def drawLinesWithMidpointContraint():
    try:
        newComp = createNewComponent()
         # Create a new sketch.
        sketches = newComp.sketches
        xyPlane = newComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        line1 = sketch.sketchCurves.sketchLines.addByTwoPoints(pnt1, pnt2)
        line2 = sketch.sketchCurves.sketchLines.addByTwoPoints(pnt3, pnt4)
        sketch.geometryConstraints.addMidPoint(line2.endSketchPoint, line1)
    except:
Message 8 of 10
BrianEkins
The sketch property is geometricConstraints, not geometryConstraints.
Brian Ekins
Message 9 of 10
Rats! Yes, this fixed the problem. I really wish the Spyder IDE editor would have given a complaint that the code was referencing an invalid namespace.
So, you might want to go edit the code sample in your initial reply, because the code is wrong there. Just don't want anyone else to try using that code and have the same issue.
Thanks for helping me.
Message 10 of 10
JesusFreke
If you want to use PyCharm instead, it has much better support for that sort of thing. See: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/now-available-fusion-360-plugin-for-intell...
It does a pretty good job inferring the type of a variable, and it will give you warnings about things like this when it can. In some cases, it can't infer the type, but you can use python type hints to help it along.
