Sketch project method in API creates unlinked geometry after the September update 2.0.14104.
Maciej_Rogowski
Maciej_Rogowski
I noticed after the September update 2.0.14104 that the sketch project method in API creates unlinked geometry.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        rootComp = design.rootComponent
        xYPlane = rootComp.xYConstructionPlane
        sketches = rootComp.sketches
        sketch = sketches.add(xYPlane)
        sketch.project(rootComp.xConstructionAxis)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It partially breaks some of my add-ins.
BrianEkins
It looks like this has been fixed in the latest update.
Brian Ekins
Maciej_Rogowski
Thank you very much for the fix. I noticed also after the September update 2.0.14337 that the sketch project method in API creates misplaced geometry if the parent component of the sketch has a different location than the parent component of the projected entity:
def run(context):
    ui = None
    try:
        matrix = adsk.core.Matrix3D.create()
        matrix.translation = adsk.core.Vector3D.create(0, 1, 0)
        occ = rootComp.occurrences.addNewComponent(matrix)
        comp = occ.component
        xYPlane = comp.xYConstructionPlane
        sketches = comp.sketches
    except:
        if ui:
It breaks one of my add-ins, when components have different locations.
