Sketch.profiles and extrusion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying the following code.The problem here is that the profiles contains inner profileLoops. Is there any way to filter that out, or should I create another profile and includes only the outer profile in profileLoops? This sounds very confusing to me.
# search for profiles that spans larger boxes than registered maxp
newprofiles = {}
for p in sketch.profiles:
if not p.isValid:
continue
bbox = p.boundingBox
d = helper.diff(bbox.minPoint,bbox.maxPoint) # diffs two points and returns vector
if d.length > maxp[0]:
newprofiles[d.length] = p
# sort and pick the largest 3
largest = []
for a in sorted(newprofiles, reverse=True):
if len(largest) < 3:
largest.append(newprofiles[a])
else:
break
pedestal = largest[0]
einput = extrudes.createInput( pedestal, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
distance = adsk.core.ValueInput.createByReal(-stepdown)
einput.setDistanceExtent(False,distance)
extrudes.add(einput)As a result, all profiles are chosen instead of the outermost one (which would span the largest bounding box). See the screenshot
