sketch.move does nothing when a particular instance of sketchLine.trim is called
lorraine5RWGT
Message 1 of 1
lorraine5RWGT
When I call `sketch.move`, nothing happens if far back in my code, I had called `line.trim`.  Problem disappears (i.e. the specific `sketch.move` works) if I comment out that specific call to `line.trim`.
Strange, because problems with `sketch.move` don't seem like they should be related to `line.trim`
line = sketch.sketchCurves.sketchLines.addByTwoPoints(p1, p2)
# (Added CoincidentConstraint and PerpendicularConstraint)
line.trim(line.endSketchPoint.geometry, True)
# Later on, in another file
returnValue = sketch.move(sketchEntities, transform)
This last `sketch.move` command only moved the sketch if the `line.trim` above was commented out, despite it always returning True.  Both instances of `sketch` refer to the same sketch in the code snippet above.
`sketchEntities` is an ObjectCollection of multiple SketchPoint.  This collection of points what all the processing is based on, meaning `line` is just one of many sketch entities that were computed from other lines that were computed from the points, etc.
This behaviour is consistent for the same data across Fusion restarts. (e.g. it consistently happens for specific sets of data, but consistently doesn't happen on other sets of data)
Replies (0)
