Sizing problem when performing a coincident constraint
vitor.carneiro
vitor.carneiro
I would like help with the following problem.
I want to include a spline inside a sketch that already contains a line, and make two constraints: the first with the first point of the line and the spline, and the second, between the end point of the line and the middle of the spline.
But I encounter the problem of a line dimension error after the constraints (decreasing its size).
Here's the code and photo of the error found.
Note 1: I really need to insert the spline in the sketch, as this is just a test for another application, where it is necessary to perform this operation.
Note 2: I need the line to remain the same 8 cm as it initially has.
Thank you very much,
Vitor Urel
kandennti
Hi @vitor.carneiro .
How about adding a DistanceDimension in advance?
# Fusion360API Python script
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des :adsk.fusion.Design = app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        sk = root.sketches.add(root.xYConstructionPlane)
        sk1 = root.sketches.add(root.xYConstructionPlane)
        points = adsk.core.ObjectCollection.create()
        pnts = [
            [0,0,0],
            [5,1,0],
            [6,4,0],
            [7,6,0],
            [2,3,0],
            [0,1,0],
        Pnt3D = adsk.core.Point3D
        for p in pnts:
            points.add(Pnt3D.create(p[0],p[1],p[2]))
        spline = sk1.sketchCurves.sketchFittedSplines.add(points)
        spline1 = sk.include(spline)
        spline2 = spline1.item(0)
        line = sk.sketchCurves.sketchLines.addByTwoPoints(
            Pnt3D.create(0,0,0),
            Pnt3D.create(8,0,0)
        # DistanceDimension
        sk.sketchDimensions.addDistanceDimension(
            line.startSketchPoint,
            line.endSketchPoint,
            adsk.fusion.DimensionOrientations.AlignedDimensionOrientation,
            Pnt3D.create(4,1,0))
        sk.geometricConstraints.addCoincident(
            spline2.startSketchPoint
            spline2
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
BrianEkins
If you want the line to remain exactly where it was before adding the coincident constraints, I think the best solution is to fix both endpoints of the line.  You can do that with something like this:
line.startSketchPoint.isFixed = True
line.endSketchPoint.isFixed = True
Brian Ekins
