Show Message Box Before Saving a Part
isocam
isocam
Can anybody help?
Is it possible, using a Python script, to show a Message Box before saving a part in Fusion 360???
For example,
Say I have created a simple sketch and extruded it.
I now want to save it.
Normally, I would press "SAVE" and manually enter the name of the part (Default shows "Untitled").
Is it possible to show, for testing purposes only, a message box saying "Hello World" before the "Save" dialog POP-UP box appears?
Many thanks in advance!
Darren
kandennti
Hi @isocam .
This can be done by using the documentSaving event.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-303438FA-9744-4C0B-9908-40BEE4184CE1
Based on the sample add-in here, I modified it to a minimal state.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a445a970-997b-11e5-b40a-3417ebd3d5be
# Fusion360API Python Addin
import adsk.core, traceback
handlers = []
ui = None
class MyDocumentSavingHandler(adsk.core.DocumentEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        ui.messageBox('HelloWorld')
def run(context):
    try:
        app = adsk.core.Application.get()
        global ui
        ui = app.userInterface
        onDocumentSaving = MyDocumentSavingHandler()
        app.documentSaving.add(onDocumentSaving)
        handlers.append(onDocumentSaving)
    except:
        if ui:
            ui.messageBox('AddIn Start Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    try:
        pass
    except:
        if ui:
            ui.messageBox('AddIn Stop Failed: {}'.format(traceback.format_exc()))
