Shortcut for a custom interface buttonDefinition
wh6Q9NU
wh6Q9NU
For a custom Add-Inn a buttonDefinition is defined (to open a commandDefinitionPanel).
How can I define a shortCut for this buttonDefinition on creation?
Thanks in advance for any help!
custom shortcut
marshaltu
Did you mean to promote custom command definition to toolbar panel? If so, it should be supported by default. One example is "Spur Gear" addin. We can promote the button to toolbar by "Add to toolbar". If it didn't work for your case, please provide workable sample to us for investigation.
Marshal
Marshal Tu
Fusion Developer
wh6Q9NU
Thanks, but the solution I'm looking for is assigning a shortcut so the custom feature can be started with single keystroke. Like the "L" for creating a Sketch line. But maybe that's not currently possible.
Shortcut example for Line: "L"
marshaltu
Unfortunately we don't have APIs to set keyboard shortcuts for commands yet. I would recommend you to log the idea to our IdeaStation so that our product management team can prioritize it and other users can vote for your idea.
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125
Marshal
Marshal Tu
Fusion Developer
