Sheeter - Google Sheets Connection for Fusion 360
prainsberry
Autodesk Autodesk
24.545Aufrufe
64Antworten
Nachricht 1 von 65
prainsberry
I wanted to post this here i case anyone is interested in checking it out.  Something I have been working on for awhile and decided to put it out there to see what people think.
This allows you to connect a Google Sheet (spreadsheet) document to a Fusion 360 design.  Then you can define multiple sizes.  Once you have defined the sizes you can switch sizes back in Fusion, or generate new Fusion models, export neutral files, or post process g-code for each size.
It is really just a bit of a hobby project for me so I make no guarantees, but in the tests I have done it has been pretty reliable.
Let me know what you think.
https://github.com/tapnair/FusionSheeter
Patrick Rainsberry
Developer Advocate, Fusion 360
Akzeptierte Lösungen (1)
24.546Aufrufe
64Antworten
Antworten (64)
Nachricht 2 von 65
Nicht anwendbar
THIS IS AMAZING
First of all: this is the first free easy bom tool. Great!
Second: Finally a good solution to do a lot of math!
third: parametric multiple exports are amazing.
I'm getting to use this right away! i've been looking to something to replace swiftcalc for a while. This is working like a charm.
Nachricht 3 von 65
smallfavor
I'm completely taken with this functionality... but it doesn't show up when I start the application
I'm pretty sure it's in the right place.  Any ideas?
https://cl.ly/3P2r3m3i3l2f
Oops!  Sorry, I just realized I had to remove the -master bit from the folder name. Thanks so much for this - it will make a very big difference!
0 „Gefällt mir“-Angaben
Nachricht 4 von 65
prainsberry
you beat me to it.  Let me know if you have any other questions.
Patrick Rainsberry
Nachricht 5 von 65
smallfavor
Hey there!
I actually do have some questions …. issues. One being the sheet is not apparently syncing! But to make things more interesting, my desktop (Mac) is randomly shutting down. I’ve had to relent and buy a newer machine. The switch from the old system in the tower to an iMac with external drives is a major frigging expense and hassle. However sometime next week I’ll be able to record with a VO alphabetize to help explain and I’ll contact. you then.
One question that arose was why columns instead of rows have to be assigned to user p’s. It would be easier if the google spread sheet could mimic more closely the layout of the Fusion window. The most tedious aspect of the fusion entry is the inability to alphabetize variables which is a nuisance down the line. But I can’t find how to do so in the google sheets either - although I think I managed to once.
Happy fourth!
James
Nachricht 6 von 65
david.lantier
Very useful, works well for me, many thanks !
Nachricht 7 von 65
Nicht anwendbar
I think it's awesome.  👍
Thank you! 😍
Nachricht 8 von 65
Nicht anwendbar
Hi Patrick, I was all set having installed Sheeter, but when I go into F360 to link to a sheet (i.e. have Sheeter create a new Google sheet for me) it redirects to a Google login screen but then when I try to login with my valid Google account I get an error saying (paraphrasing) something like "Google cannot allow in-app authentication as this software developer has not been verified or authorized" or something to that effect.  So i can't get any further, and this also has the effect of hanging F360 in a loop that requires me to Force Quit (I'm using Mac OS X).
Any way around this?  i'm eager to get going with Sheeter!
thanks
Carl
Nachricht 9 von 65
Nicht anwendbar
Hi @Anonymous & @prainsberry
I have the same issue - tested on Mac & PC, company g-mail, personal g-mail as well as with and without 2 factor authentication. Any guidance would be awesome.
Jeff
Nachricht 10 von 65
prainsberry
Hello @Anonymous  and @Anonymous I am afraid maybe Google has update a security policy.  I will look into it, but I hope this doesn't mean the end of Sheeter...
Will report back soon.
Patrick Rainsberry
Nachricht 11 von 65
Nicht anwendbar
Patrick, thanks for the follow up.  I don't suppose there's a way for Sheeter to work with a local copy of, say, an excel spreadsheet (thus avoiding the need to go through Google's security. ???
thanks
Carl
Nachricht 12 von 65
Nicht anwendbar
I am praying that this google security issue is resolved so that we can get back up and running. This plug-in solves 90% of my problems with F360.
Nachricht 13 von 65
prainsberry
Hey, sorry for the delay.  I have looked into the issue with Google and understand what is necessary to resolve it.  Google is enforcing a pretty intense security policy now.
That said I am working through some logistics right now, and should be able to give you an answer one way or another soon.
Patrick Rainsberry
Nachricht 14 von 65
prainsberry
Update:  Basically spent the whole weekend getting everything setup , but I have submitted this to Google for "verification".  There will be a new "version" of the app that you will need to download moving forward.  I am just getting some last things tied up but I think the "new one" should be available in the next couple days.  It will work for the first 100 people that use it until the Google Verification Process is complete (they say up to 4-6 weeks).  I will post an update here as soon as the "new one" is available.  Maybe will get it finished tonight.
Patrick Rainsberry
Nachricht 15 von 65
Nicht anwendbar
That is great. Thank you!
Nachricht 16 von 65
n3rDlab
Akzeptierte Lösung
Hello All,
So I think I have this all set up!!  In order to comply with Google Security policy I needed to move this into an "organization" rather than my personal Google account.  Well that spawned a lot of things LOL.
The good news is I actually already completed the full verification process with Google so it should be fully working now.
To continue to use it, you'll need to download the new version.  Please forgive me if there a kinks in the website.  You have no idea how long it took to just get to this point.  Also please note, I used this "store" template for the website, but to be very clear I have no intentions of charging for Sheeter.
Here you go:
https://n3rdlab.com/downloads/sheeter/
Nachricht 17 von 65
iUser2k13
Observer
Observer
connection to sheet works, but problems to export STL files.
Nachricht 18 von 65
prainsberry
Are you able to manually export an stl of that Fusion design?
Patrick Rainsberry
Nachricht 19 von 65
Nicht anwendbar
Hi folks,
Hope everyone is doing well. I recently downloaded the sheeter add in and followed all steps to integrate it with Fusion, which I believe I did correctly. Yet, when I try to sinc with the google sheets, I get the error in the attached picture...
Any help would be appreciated!
Nachricht 20 von 65
Nicht anwendbar
Nevermind! I just restarted Fusion and now it is working!
