Sheeter - Google Sheets Connection for Fusion 360
prainsberry
Autodesk Autodesk
Message 1 of 65
prainsberry
I wanted to post this here i case anyone is interested in checking it out.  Something I have been working on for awhile and decided to put it out there to see what people think.
This allows you to connect a Google Sheet (spreadsheet) document to a Fusion 360 design.  Then you can define multiple sizes.  Once you have defined the sizes you can switch sizes back in Fusion, or generate new Fusion models, export neutral files, or post process g-code for each size.
It is really just a bit of a hobby project for me so I make no guarantees, but in the tests I have done it has been pretty reliable.
Let me know what you think.
https://github.com/tapnair/FusionSheeter
Patrick Rainsberry
Developer Advocate, Fusion 360
Replies (64)
Message 61 of 65
jhogarthHG7H
Observer
Observer
Message 62 of 65
florianADZZ4
After the latest Fusion update Sheeter wont start anymore. Was to be expected. But I was wondering if Patrick if planning to work on a update?
Message 63 of 65
fndecker
Community Visitor
Community Visitor
Since this won't work anymore, I finally figured out how to go to the utilities menu on the main menu bar, select add-ins, uncheck the box for "load at startup", see on that screen where it was installed from, and then delete everything manually in that folder from the windows file manager.
Message 64 of 65
ped_am
Observer
Observer
Any updates on this topic?
Message 65 of 65
simoncriswell
Community Visitor
Community Visitor
The n3rdlab.com site seems broken/hacked, really want to use Sheeter. Can anyone help with sheeter download files?
