Setting model parameters
jeremiahrose
jeremiahrose
I am using the API to sketch many circles like this:
circle = sketch.sketchCurves.sketchCircles.addByCenterRadius(center, 10)
However, what I actually want to do is set each circle's radius to equal a user parameter called "userRadius". If I was doing this in the UI, I would sketch the circle and enter the string "userRadius" into the radius input box, but the addByCenterRadius function does not accept a string.
I'm aware that you can use the ModelParameters object to get an individual parameters by calling "itemByName", but this isn't useful at all because I do not know the name of the parameter. And I can't find a way to get the parameter name ("d1" "d22" "d76" etc) from the circle object.
How do I create an object and set its dimensions to equal a user parameter in the API? How do I create a model parameter? How do I find the model parameters associated with a particular object if all I have is the object as a variable?
Thanks!
Jerry
jeremiahrose
Figured it out. I needed to add a SketchRadialDimension to the SketchCircle, then access the ModelParameter from there and set it's expression:
# create a SketchCircle with a placeholder radius. centerPoint is a Point3D
circle = sketch.sketchCurves.sketchCircles.addByCenterRadius(centerPoint, 1)
# create a SketchRadialDimension to constrain the circle's radius. textPoint is the position of the dimension's text.
rd = sketch.sketchDimensions.addRadialDimension(circle, textPoint, True)
# Set the expression of the parameter
rd.parameter.expression = 'userRadius'
