Setting model expression formulas
brad.bylls
brad.bylls
I am trying to set a model parameter expression in a script.
# Create the body clearance
    cutBodySketch = sketches.add(xyPlane)
    cutBodyCircle = cutBodySketch.sketchCurves.sketchCircles.addByCenterRadius(center, numBoltClearDiam/2)
    cutBodySketch.sketchDimensions.addDiameterDimension(cutBodyCircle, adsk.core.Point3D.create(0, 1, 0))
    cutBodySketch.name = 'Body Clearance Sketch'
    cutBodyProf = cutBodySketch.profiles[0]
    cutBodyExtInput = extrudes.createInput(cutBodyProf, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    distance = adsk.core.ValueInput.createByReal((numBoltBodyLength-(numBoltBodyDiam * numThreadEngage)) * -1)
    cutBodyExtInput.setDistanceExtent(False, distance)
    cutBodyExt = extrudes.add(cutBodyExtInput)
    cutBodyExt.name = 'Body Clearance Extrude'
    cutBodyExt.expressions = 'd2 - ((d1 * 1.5) * -1 )'
The last line does not produce an error.
Is it possible to do this?
Brad Bylls
goyals
From the code you shared it looks like you are setting expressions property on extrude feature but no such property exists there so it should throw exception. Expression set property is available on parameter class http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-0e50e797-b406-4c51-9bdb-d9aa62af920b
Shyam Goyal
Sr. Software Dev. Manager
brad.bylls
Thanks for the input.
However, that is for user parameters.
I want to put a formula in a model parameter.
Brad
Brad Bylls
brad.bylls
I can't see the replies so I don't know if it solved.
Brad Bylls
goyals
I just found an old post showing how you can reference model parameters in an expression to create a feature.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/reference-to-modelparameter-object-in-an-e...
This is example in API documentation showing how to use expression property of model parameters
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-CB1A2357-C8CD-474D-921E-992CA3621D04
I hope it helps. Thanks.
Shyam Goyal
brad.bylls
It was complicated but I figured it out from the second link.
Thank you so much.
Brad Bylls
