Setting isAutomaticSaveOnCloseEnabled doesn't work
scottmoyse
Mentor Mentor
scottmoyse
If you try the following code it doesn't change the setting in preferences:
    app = adsk.core.Application.get()
    ui = app.userInterface
    genPref = app.preferences.generalPreferences
    autosave = genPref.isAutomaticSaveOnCloseEnabled
    autoVersion = genPref.isAutomaticVersioningEnabled
    print("Autosave before: " + str(autosave))
    print("autoVersion before: " + str(autoVersion))
    if autosave:
            autosave = False
    print("Autosave: " + str(autosave))
    print("autoVersion: " + str(autoVersion))
You can see from the result in the debug console that the value has changed so far as the API is concerned. But when you check the UI, the setting is still ON... and running the code again reports autosave is True.
If I turn off the setting manually, then autosave evaluates to False immediately.
It appears there are a decent number of bugs in the API and a few misleading notes in the documentation indicating things should work when in fact they aren't supported. Who is responsible for logging bugs and how many API bug fixes are pushed out with each new release of Fusion?
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
goyals
I just looked at your code. You change the value of variable locally and not set it on API again.  Please try below code.
if autosave:
  genPref.isAutomaticSaveOnCloseEnabled = False
Thanks.
Shyam Goyal
Sr. Software Dev. Manager
scottmoyse
yeah I tried that before posting on here, that doesn't work either.
Kind Regards
Scott Moyse
Manufacturing Technical Specialist Autodesk Expert Elite
P: +64 9 302 4028 M: +64 21 055 7775
scott.m@cadpro.co.nz
CADPRO Systems Ltd
Auckland - 527b Rosebank Road, Avondale Auckland
Christchurch - Unit 3, Kendal Avenue, Burnside
New Zealand
Scott Moyse
scottmoyse
if autosave:
Thanks.
I take that back... This does work. I mustn't have tested it properly previously. Thank you.
Scott Moyse
