Set the "Physical Material" using a Python script
isocam
isocam
Can anybody help?
Is it possible to set the "Physical Material", of a part, using a Python script?
For example,
Say I have a simple part already open, can I set the "Physical Material" to Aluminium 7075 or any other material?
Many thanks in advance
Darren
BrianEkins
Here's a small example.
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design: adsk.fusion.Design = app.activeProduct
        # Get the material.
        lib = app.materialLibraries.itemByName('Fusion 360 Material Library')
        aluminum = lib.materials.itemByName('Aluminum 7075')
        # Get a component. In this case, using the name.
        comp = design.allComponents.itemByName('Component1')
        # Check if the component is local or linked. Only local components can be edited.
        if comp.parentDesign == design:
            # Set the material.
            comp.material = aluminum
        else:
            ui.messageBox('Cannot set material on linked component.')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
