Set IsReadOnly for StringValueCommandInput
-pezi-
Message 1 of 9
-pezi-
It is possible set IsReadOnly for StringValueCommandInput when adding new row in TableCommandInput? Because this option works for me only if I doing settings in CommandCreatedEventHandler.
Replies (8)
Message 2 of 9
kandennti
Hi @-pezi- .
I made and tried something like this.
# Table Cell ReadOnly Test
import adsk.core, adsk.fusion, traceback
_commandId = 'Table Cell ReadOnly Test'
_tblIpt = adsk.core.TableCommandInput.cast(None)
_tblAddBtnIpt = adsk.core.BoolValueCommandInput.cast(None)
_handlers = []
_app = None
_ui = None
class CommandInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            global _tblAddBtnIpt
            if args.input != _tblAddBtnIpt:
                return
            addRowToTable()
        except:
            if _ui:
                _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class CommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
            if _ui:
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            # event
            onDestroy = CommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onInputChanged = CommandInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            # inputs
            inputs = cmd.commandInputs
            global _tblIpt, _tblAddBtnIpt
            tblStyle = adsk.core.TablePresentationStyles
            _tblIpt = inputs.addTableCommandInput('table', 'Table', 5, '1')
            _tblIpt.hasGrid = False
            _tblIpt.tablePresentationStyle = tblStyle.itemBorderTablePresentationStyle
            _tblAddBtnIpt = inputs.addBoolValueInput('tableAdd', 'Add', False, '', True)
            _tblIpt.addToolbarCommandInput(_tblAddBtnIpt)
            # Add 2 lines in advance
            addRowToTable()
            addRowToTable()
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDefs = _ui.commandDefinitions
        cmdDef = cmdDefs.itemById(_commandId)
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = cmdDefs.addButtonDefinition(_commandId, _commandId, _commandId)
        onCmdCreated = CommandCreatedHandler()
        cmdDef.commandCreated.add(onCmdCreated)
        _handlers.append(onCmdCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
# Add row to table
# Even number:readOnly
# Odd number:read/write
def addRowToTable():
    global _tblIpt
    inputs = adsk.core.CommandInputs.cast(_tblIpt.commandInputs)
    rowCount = _tblIpt.rowCount
    if rowCount % 2 == 0:
        info = ('readOnly', True)
    else:
        info = ('read/write', False)
    txtIpt = inputs.addStringValueInput(
        'txt{}'.format(rowCount), info[0], info[0])
    txtIpt.isReadOnly = info[1] # OK
    _tblIpt.addCommandInput(txtIpt, rowCount, 0)
    # txtIpt.isReadOnly = info[1] # NG
Is "IsReadOnly = True" set before addingCommandInput?
Message 3 of 9
-pezi-
Hi @kandennti
Thank you for the quick reply. Your example works well. But I'm creating a TableCommandInput on the second TabCommandInput and here's its behavior, as I wrote earlier. I tried to edit the example http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-e5c4dbe8-ee48-11e4-9823-f8b156d7cd97
	// Create three new command inputs.
	Ptr<CommandInput> childTableValueInput = cmdInputs->addValueInput("TableInput_value" + rowId.str(), "Value", "cm", ValueInput::createByReal(rowNumber));
	Ptr<StringValueCommandInput> childTableStringInput = cmdInputs->addStringValueInput("TableInput_string" + rowId.str(), "String", rowId.str());
	Ptr<CommandInput> childTableSpinnerInput = cmdInputs->addIntegerSpinnerCommandInput("spinnerInt" + rowId.str(), "Integer Spinner", 0, 100, 2, rowNumber);
	childTableStringInput->isReadOnly(true); // This is my edit
but the result is the same as in my code (when adding a line, the readOnly setting is not respected).
Message 4 of 9
kandennti
Fixed the table to be set in a tab.
_handlers = []
_app = None
_ui = None
    def __init__(self):
        super().__init__()
        try:
                return
            addRowToTable()
        except:
            pass
            # if _ui:
            #     _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
            if _ui:
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            # event
            # inputs
            tab1 = inputs.addTabCommandInput('tab_1', 'Tab 1')
            tab1ChildInputs = tab1.children
            tab2 = inputs.addTabCommandInput('tab_2', 'Tab 2')
            tab2ChildInputs = tab2.children
            _tblIpt = tab2ChildInputs.addTableCommandInput('table', 'Table', 5, '1')
            addRowToTable()
            addRowToTable()
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef.execute()
    except:
        if _ui:
# Add row to table
    global _tblIpt
    else:
It is true that "IsReadOnly = True" doesn't seem to be working outside of the CommandCreatedEvent.
Perhaps adding a row to the table outside of a CommandCreatedEvent is not supposed to be done.
Message 5 of 9
nnikbin
Hi @-pezi-
In 2019, I reported almost the same problem here.
Is the text that you need in your table rows always readonly?
Message 6 of 9
-pezi-
Hi, @nnikbin
thanks for your reply. And yes my text in a row is always readonly. I want to create CommandInputs with two TabCommandInput. On the first Tab will be TableCommandInput when show columns which are possible configuration second TabCommandInput. Because count of columns can be variable, on switching from configuration's tab on a view (first tab), I doing deleting all rows, and again adds rows with columns by configuration on the second tab.
Message 7 of 9
nnikbin
@-pezi-
I had the same problem in my add-in. Finally I found a good solution. I used BoolValueCommandInput (Button) and made it readonly. By setting its text property (without icon) it acts like a readonly StringValueCommandInput.
In following picture all numbers are BoolValueCommandInput.
Message 8 of 9
-pezi-
Hi @nnikbin
thank you for your tip it is a good solution for me.
Message 9 of 9
nnikbin
You are welcome @-pezi-
I am glad it helped. I hope Autodesk solve the root issue soon.
