Selection Input
Selection Input
dinocoglitore
Selection Input
dinocoglitore
Hi all, I'm having problems with a multiple selection of curves from an Command Dialog.
I din not find any example on the forum or in the documentation so I am asking some help or some example code.
These are extracts from the Add-in I'm trying to write:
Inside the  SampleCommandCreatedHandler I have this code
# Create selection input
curve_input = inputs.addSelectionInput('curve_input', 'Select', 'Select curve')
# select only curves
curve_input.addSelectionFilter('SketchCurves')
# I can select more than one curve
curve_input.setSelectionLimits(0)
Inside the SampleCommandExecuteHandler I have this code
# count the number of curves selected
n_selection = inputs.itemById('curve_input').selectionCount
# get the curve selected and call helix()
for i in range (0, n_selection 😞
cur = inputs.itemById('curve_input').selection(i)
curve = cur.entity
# call a function witn the curve selected
helix( curve )
I do not understand the reason why I receve this error
If I select 3 curves and use the following instruction
cur = inputs.itemById('curve_input').selection(0)
or
cur = inputs.itemById('curve_input').selection(1)
or
cur = inputs.itemById('curve_input').selection(2)
they do not provide error
Someone can help me ?
Many Thanks
Dino
ekinsb
Selections are somewhat fragile and doing something that changes the database in any way will usually clear any current selections.  I believe that's the problem you're running into here. Whatever your helix command is doing is also having the side effect of clearing the current selection so when you try to get the next entity in the selection it fails.  To work around that you can first get everything from the selection and then do the processing, like shown below.
curves = []
for i in range (0, n_selection ):
    curves.append( inputs.itemById('curve_input').selection(i).entity )
for curve in curves:
    helix( curve )
Brian Ekins
Mod the Machine blog
dinocoglitore
Hi Brian, thank you very much for your answer. It obviously solved my problem and make me climb another rung in the kwnoledge of API and Python.
Dino
2way3dtext
Dear kandennti
