selectEntity problem (documentation vs application)
brad.bylls
Message 1 of 9
brad.bylls
I have script that requires the user to pick a 'PlanarFace'
According to the documentation, this should work.
returnValue = userInterface_var.selectEntity(prompt, filter)
However, when I run the script:
# Create a new sketch.
    sketches = newComp.sketches
    xyPlane = adsk.core.UserInterface.selectEntity('Select Face''PlanarFaces')
    center = adsk.core.Point3D.create(000)
I get this exception error looking for another argument?
Brad Bylls
Replies (8)
Message 2 of 9
BrianEkins
The error is a bit misleading but I think you're getting it because you're attempting to use it like a static function. Instead you need to call it from an existing UserInterface object. Assuming you have a variable named "ui" that references the UserInterface you would call it like this:
xyPlane = ui.selectEntity('Select Face', 'PlanarFaces')
Brian Ekins
Message 3 of 9
kandennti
Hi @brad.bylls .
A follow-up to@BrianEkins' advice.
The return value of the selectEntity method will be a Selection object rather than a selected entity.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-c05f97b8-9c8f-404b-8b21-f170d194ef8e
You can also press the ESC key during the selection process to abort the process, but this will raise an exception.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/bug-userinterface-selectentity-should-retu...
For this reason, we recommend that you do something like this.
        app = adsk.core.Application.get()
        ui = app.userInterface
        try:
            returnValue = ui.selectEntity('Select Face', 'PlanarFaces')
        except:
            return
        xyPlane = returnValue.entity
Message 4 of 9
brad.bylls
I tried that and get the same error.
Brad Bylls
Message 5 of 9
brad.bylls
I tried this.
Did not get an error message, but no UI came on the screen asking to pick a face.
In debugging, I stepped through the code and nothing happened.
Brad Bylls
Message 6 of 9
kandennti
Beyond this, you can't judge without seeing your actual source code.
Message 7 of 9
brad.bylls
    ui = adsk.core.UserInterface
    xyPlane = ui.selectEntity('Select Face''PlanarFaces')
Brad Bylls
Message 8 of 9
kandennti
I've modified this sample here.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-ecd3b76b-19f7-4efa-8a02-087c16da246f
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        # doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        design = app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches
        # xyPlane = rootComp.xYConstructionPlane
        try:
        except:
            return
        sketch = sketches.add(xyPlane)
        # Draw some circles.
        circles = sketch.sketchCurves.sketchCircles
        circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 2)
        circle2 = circles.addByCenterRadius(adsk.core.Point3D.create(8, 3, 0), 3)
        # Add a circle at the center of one of the existing circles.
        circle3 = circles.addByCenterRadius(circle2.centerSketchPoint, 4)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I wanted everything to be public, including the declaration part.
Message 9 of 9
brad.bylls
It does not give the user a command prompt to pick a face.
It does work when you do pick a face.
It's just that the user won't know to do that.
Brad Bylls
