Script SpurGear, have problem with parameter RootFilletRadius
cadTPLWJ
cadTPLWJ
I have played with the supplied script SpurGear. I have not changed the actual script in any way.
When I create a small gear with the script, the RootFilletRadius is rendered to my liking.
When I create a larger gear the RootFilletRadius does not look like a fillet.
It seems like the actual fillet in the timeline is not what I expect. Even if I reselect the edge, the fillet does not seem right.
What is the difference between these two instances?
The test example is included as f3d.
ekinsb
Thanks for reporting this and providing the example file.  I see the problem and it will need a fix.  Unfortunately it's too late for the upcoming update in March but should be in the update after that.
Brian Ekins
Mod the Machine blog
