RuntimeError: 3: Environment is not supported
11713013
11713013
Hi, experts in Fusion360!
I met a problem when I want to create a construction point using following code:
# create a geo point
        point1 = adsk.core.Point3D.create(0, 20, 0)
        cons_points = rootComp.constructionPoints
        cons_point_input = cons_points.createInput() # create a constructionPointInput var
        cons_point_input.setByPoint(point1) # set by point
        point = cons_points.add(cons_point_input)
        geo_point = adsk.fusion.JointGeometry.createByPoint(point)
And the problem came out:
What is the "Environment" mean here? Is the python environment or the Fusion360 environment?
I search for the error "RuntimeError: 3: Environment is not supported" in google and this forum but do not find any thing.
Hoping for the community's help.
Thanks a lot!
And Merry Christmas to all the community and the Fusion360 experts!
j.han97
Hi @11713013 ,
Are you working in parametric design mode (with capture design history ON)? In the documentation here, it is stated that this line
constructionPoint = constructionPoints.add(input)
only works in direct edit mode (turn OFF capture design history).
Hope it helps.
You are right! After turn off Capture Design History, it works.
Thank you so much!
Merry Christmas!
j.han97
Merry Christmas!
