RuntimeError: 2 : InternalValidationError : results
NuofanQiu
Message 1 of 8
NuofanQiu
I currently write an add-in to import models into design but I can only import one model at a time.
Import only one manipulator or one gripper works. But import manipulator and gripper at the same time, something went wrong:
Traceback (most recent call last):
  File "C:\Users/Aspartame/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/AddIns/ImportRobot\lib\fusion360utils\event_utils.py", line 84, in notify
    callback(args)
  File "C:\Users/Aspartame/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/AddIns/ImportRobot\commands\importRobot\entry.py", line 138, in command_execute
    import_robot.importManipulator(gripper.name)
  File "C:\Users/Aspartame/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/AddIns/ImportRobot\commands\importRobot\import_robot.py", line 40, in importManipulator
    importManager.importToTarget(f3dOptions, rootComp)
  File "C:\Users/Aspartame/AppData/Local/Autodesk/webdeploy/production/b4885f4229f39fee5ad2bce82f309e671e5c9ccd/Api/Python/packages\adsk\core.py", line 10892, in importToTarget
    return _core.ImportManager_importToTarget(self, importOptions, target)
 But I test it using a script works well, here is the `test.py`:
import adsk, adsk.core, adsk.fusion
import os, sys
import pathlib
import time
def importManipulator(name: str):
    name: name of manipulator
    app = adsk.core.Application.get()
    ui = app.userInterface
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    rootComp = design.rootComponent
    importManager = app.importManager
    viewPort = app.activeViewport
    currentCamera = viewPort.camera
    # change the view to make z-axis with a up direction
    camera_up_vector = adsk.core.Vector3D.create(0.0, 0.0, 1.0)
    currentCamera.upVector = camera_up_vector
    viewPort.camera = currentCamera
    _ = viewPort.refresh()
    current_dir = os.path.dirname(os.path.abspath(__file__))
    if name == "None":
        return # do nothing
    if name == "UR5e":
        model_file = current_dir + "/robot_models/UR5e.f3d"
        f3dOptions = importManager.createFusionArchiveImportOptions(model_file)
        f3dOptions.isViewFit = True
    if name == "Robotiq85 Gripper":
        model_file = current_dir + "/robot_models/Robotiq_2F85_Gripper.f3d"
importManipulator("UR5e")
importManipulator("Robotiq85 Gripper")
But I don't know what is wrong with the add-in code. I iput it at GoogleDrive hoping you can help with me. By now, I only have two `f3d` file so you can just pick `UR5e` model and `Robotiq85 Gripper` as the selection.
My add-in file at GoogleDrive:
Add-in at GoogleDrive
Thanks a lot!
Replies (7)
Message 2 of 8
kandennti
Hi @NuofanQiu .
I made a script and tried it. The f3d files used are the same.
This one simply imports two f3d files.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import pathlib
THIS_DIR = pathlib.Path(__file__).resolve().parent
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        paths = [
            str(THIS_DIR / 'robot_models' / 'Robotiq_2F85_Gripper.f3d'),
            str(THIS_DIR / 'robot_models' / 'UR5e.f3d'),
        import_f3ds(paths)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def import_f3ds(paths: list[str]) -> None:
    try:
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        importMgr: core.ImportManager = app.importManager
        for path in paths:
            importOpt: core.FusionArchiveImportOptions = importMgr.createFusionArchiveImportOptions(
                path,
            importMgr.importToTarget(importOpt , root)
    except:
        app.log('Failed:\n{}'.format(traceback.format_exc()))
This one was handled correctly.
The next script uses a dialog.
It is longer, but the import process itself is the same.
import traceback
import adsk
import pathlib
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    'id': 'kantoku_test',
    'name': 'test',
    'tooltip': 'test'
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        core.Application.get().log(args.firingEvent.name)
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            txtIpt: core.TextBoxCommandInput = inputs.addTextBoxCommandInput(
                'txtIpt',
                'test',
                'Click OK',
                1,
                True
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyExecuteHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        paths = [
        import_f3ds(paths)
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO['id']
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO['id'],
                CMD_INFO['name'],
                CMD_INFO['tooltip']
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
    try:
        for path in paths:
                path,
    except:
This one can reproduce the situation because it is not possible to import.
The main difference is the use of CommandDefinition.
The first f3d is imported, but the second one fails and the imported one disappears.
Perhaps the transaction is causing the process to revert.
There was a crash bug with the importToTarget method in the past.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/addin-cause-the-crash-shutdown-of-fusion-a...
It was fixed in a relatively short time, but I think it is probably incomplete.
Also, using the importToTarget2 method causes the same problem.
I feel it is a bug.
Message 3 of 8
NuofanQiu
Yes, I have the same result as you mentioned:"The first f3d is imported, but the second one fails and the imported one disappears.".
Thank you for you reply. I will try to avoid it.
Message 4 of 8
espablo
I just had the same problem. I see it hasn't been fixed yet because I'm also trying to load the f3d file for the second time and I can't because I get this error: "RuntimeError: 2 : InternalValidationError : pBase"
Message 5 of 8
BrianEkins
I recently learned about an undocumented limitation when opening and importing files. Internally, the API calls a command to do this, which causes problems when you're running within a command, which you are in this case. That's why it works as a script because you're not in a command. I'm not sure how to work around this limitation. I think it might be possible, but it would take some experimenting to see what will work.
Brian Ekins
Message 6 of 8
espablo
Have you managed to solve this problem?
Message 7 of 8
tjbatche
Just commenting to see if there have been any improvements on this problem. I am currently in a situation where I need to import multiple step files and can't seem to find a simple workaround for this issue.
Message 8 of 8
Jorge_Jaramillo
I believe that this situation can be solved with a custom event or with a second process thread, which emit a message to import each file.
This way the execute event handler from the AddIn runs to collect user input and prepare the messages to be sent to the custom event handler.
Then in the custom event handler (not in parallel with the execute handler) it can import each file or make any operation on its own working space.
I'd made it in the past with some implementations without any problem.
Jorge Jaramillo
