Run Python Script On First Save
isocam
isocam
Can anybody help?
I have a Python script that runs every time the user presses the "Save" button.
This Python script works extremely well.
However,
If I create a brand new part and press the "Save" button, the script does not run. It only runs on the second press of the "Save" button.
My question is....
Is there a way of modifying the Python script file so that it runs on the very first save as well?
Many thanks in advance!
Darren
kandennti
Hi @isocam .
I created an add-in that uses documentSaved Event for testing purposes.
# Fusion360API Python Addin
import adsk.core, adsk.fusion, traceback
_app = None
_ui  = None
_handlers = []
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            global _app
            _app.get().log(f'FiringEventName : {args.firingEvent.name}')
            global _handlers
            cmd = adsk.core.Command.cast(args.command)
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onDocumentSaved = MyDocumentSavedHandler()
            _app.documentSaved.add(onDocumentSaved)
            _handlers.append(onDocumentSaved)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyDocumentSavedHandler(adsk.core.DocumentEventHandler):
    def __init__(self):
        super().__init__()
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef = _ui.commandDefinitions.itemById('Test')
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition('Test', 'Test', 'Test')
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        _app.get().log('-- Start addin --')
        adsk.autoTerminate(False)
    except:
        if _ui:
def stop(context):
    try:
        _app.get().log('-- Stop addin --')
    except:
        if _ui:
I ran the add-in and saved a new document. I got "DocumentSaved" in the log, so the first save is working correctly.
Without seeing what you have created, I don't think anyone can answer your question.
