rotary joint without features
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've generated several components, one in each file. Every component has at least one 3DconstructionPoint on a ConstructionAxis for the later joint definition.
The joints for the assembly shall be rotary joints (aligning one axis of each component coaxially with the corresponding axis of another component) and the 2 point on those axis shall conincide.
In Inventor this task is very straightforward (mate both axis and both points). I'm struggling to get the alignment done in the UI as well as in the API.
I did extrude a cylinder along the axis and centered at the point in each part and the alignment work perfetcly in the UI using those bodys. But since the components are more conceptual for now, I don't want any bodys to be involved in the joint definitions. Is there a good, deep tutorial for generating joints, jointgeometries, jointorigins and how they interact. It's a very complex field in 3D modeling and the documentation on it seems to be unsufficient.
Big Thanks,
Stefan
