Render multiple individual items for Ml dataset
mpsilcock
Observer Observer
mpsilcock
Observer
Observer
Is there a way to create a batch file render script?
I have a few 1000 files that I would like to open, render and save a basic render with no background from a few angles for a machine vision project.
Maybe change the material colour too...
I am hoping that I can use some sort of batch file script to keep the files called the same-ish name and folder location.
I would rather learn how to do it in Fusion rather than start on a new program just for this task.
I have a fairly good understanding of python.
BrianEkins
This is certainly possible. Here are a few links to documentation and samples that, put together in the right way, should give you what you need.
  1. Opening Files - https://forums.autodesk.com/t5/fusion-360-api-and-scripts/api-to-open-a-specific-file/m-p/10753366
  2. Setting the view - You'll use the active viewport and its camera. Here's a blog post about cameras. It's specific to Inventor, but the concepts apply to Fusion. https://modthemachine.typepad.com/my_weblog/2013/09/working-with-cameras-part-1.html
  3. Saving the image is demonstrated in this sample: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-33127518-f20a-11e5-bab1-a0a8cd5c2c67. Although there is a new saveAsImageFileWithOptions method that will allow you to specify a transparent background. https://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/files/Viewport_saveAsImageFileWithOptions.htm
  4. Here's a blog post about changing colors. https://ekinssolutions.com/setting-colors-in-fusion-360/
Brian Ekins
mpsilcock
Observer
Observer
Thanks, that looks like a good plan
