Renaming entity leads to selection reset
kriomant
kriomant
I use `entity.name = newName` in my add-in code. If renamed entity is selected, after renaming selection is lost. Is it intended behavior?
BrianEkins
I think this is the expected behavior. Anything that creates a transaction will clear the current selection and setting the name is a transacted operation, (causes an item to be added to the undo list).
Brian Ekins
kriomant
Ok. I'm able to work around it. But what is rationale for such behavior?
When user renames objects using UI, selection is preserved.
