Rename Component part numbers
smithweyer
smithweyer
I have a project file that I have messed up with several hundred brackets in the part names and I want to have a script to remove them and fix the naming so I can make up my bill of materials without manually going through the bill of materials or the file to fix them.. I did find a find and replace script for the component names although I'm not sure if its working properly and Id like to modify it or make a python version. I'm not much of a programmer but I can change values. lol
here is the link to the file it's called renameComp
www.cadstudio.cz/en/download.asp?ccat=33
thanks for any help.
smithweyer
I modified the component.name parameter to component.partName and that seemed to work. The regular expression /(.* seemed to work to remove most of the crap, what expression would you use to remove a version number?
