Reference to ModelParameter object in an expression property?
After much experimentation, searching of the forum and exploration of the API documentation, I've been unable to answer a pretty simple question: Is it possible to include a reference to a ModelParameter in the expression property of a UserParameter or another ModelParameter? If it is possible, I'd very much like to know how!
For example, if I have a ModelParameter whose name property is "D23" and I'd like to add a SketchOffsetDimension whose value is, say, 0.25 times the current value of the "D23" ModelParameter, how can I do that? I'm sure I'm not the first person with this use case, but I simply can't figure out how to make it happen.
I'd really appreciate any hints!
BrianEkins
Here's a small example that creates a diameter dimension that is based on an existing parameter named "MyValue".
def run(context):
    try:
        app = adsk.core.Application.get()
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        # Create a new sketch.
        sk = root.sketches.add(root.xYConstructionPlane)
        # Draw a circle.
        circ = sk.sketchCurves.sketchCircles.addByCenterRadius(adsk.core.Point3D.create(0,0,0), 5)
        # Add a diameter constraint.
        skDim = sk.sketchDimensions.addDiameterDimension(circ, adsk.core.Point3D.create(5,5,0), True)
        # Set the expression of the parameter controlling the dimension constraint.
        skDim.parameter.expression = 'MyValue / 4'
    except:
        app.userInterface.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Thanks for responding and for the example code. The use case I'm struggling with is just slightly different. If I understand correctly, in example code, "MyValue" is the name of a UserParameter object. In the case I'm struggling with the reference has to be to a ModelParameter object.
Extending the example a little:
def run(context):
    try:
        <A bunch of code that creates two SketchPoint objects, pointOne and pointTwo,
        from information elsewhere in the design.>
        # Make a driven dimension across the two points of interest
        dim = sk.sketchDimensions.addDistanceDimension(
            pointOne,
            pointTwo,
            adsk.fusion.DimensionOrientations.AlignedDimensionOrientation,
            adsk.core.Point3D.create(0, 0, 0),
            False)
        # Draw a circle.
        # Set the controlling the dimension constraint to be 1/4 the distance from pointOne to pointTwo.
        skDim.parameter.expression = dim.parameter.name + ' / 4'
    except:
This doesn't work because, it appears, dim is a ModelParameter, not a UserParameter. Does this make sense?
BrianEkins
My sample code will work with either user or model parameters.  The difference with your code is that the parameter you're trying to reference is associated with a driven dimension constraint.  Fusion 360 doesn't support creating a reference to a driven dimension.  If you look at the parameters dialog, you'll find that parameters associated with driven dimensions aren't displayed so you can't try and create any equations using them.
Brian Ekins
Ah, thanks so much for the clarification. Yes, I do see that if I enter the name of a ModelParameter that's not a driven dimension in the  Modify->Change Parameters dialog I can create an equation involving that. But if I enter the name of the driven dimension's parameter object, the name reference stays red.
So, I need to figure out a different way of creating an equation that represents the distance between two SketchPoint objects. I need an equation because, for a parametric model, the distance between the two points is an arbitrary function of parameters that the user could change. A driven dimension looked so appealing for that.
