Reference to bRepBody Create from an Extrusion
codefoster
codefoster
If I (via the API) create a sketch and then extrude it, a bRepBody is created. How do I get a reference to that body without having to use some sort of logic to select it. I want the body that resulted from the extrusion.
liujac
You may add attributes to the BRepBody and find the BRepBody by attributes. Please read: http://fusion360.autodesk.com/learning/learning.html?guid=GUID-BAF017FE-10B8-4612-BDE2-0EF5D4C6F800.
Jack
ekinsb
The ExtrudeFeature object supports the bodies property which returns the body(s) that were created or modified by the feature.  If you specified that a new body should be created by the feature, then this will return the new single new body.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
codefoster
Great. I think this will be my solution. Thanks, Brian.
