"Invalid entity" when defining a rotate move feature
joe_m_ferner
joe_m_ferner
I'm trying to write some Python code to create a rotate move feature on a body.
center_axis = comp.constructionAxes[0]
mci = adsk.core.ObjectCollection.create()
mci.add(my_feature.bodies[0])
mi = comp.features.moveFeatures.createInput2(mci)
mi.defineAsRotate(center_axis, adsk.core.ValueInput.createByString("10 deg"))
When "defineAsRotate" is called I get "Runtime Error: 3 : Invalid entity"
If I instead call "defineAsTranslateXYZ" it does indeed translate the body. I have also manually rotated the feature using the UI selecting my body and construction axis and it works correctly.
I must be missing something on how I'm supposed to call "defineAsRotate"
Full code here: https://github.com/joeferner/YAGA/blob/master/commands/spur_gear/spur_gear.py#L566-L569  and yes I know about the built in spur gear add-in and various other add-ins, I'm trying to make my spur gear add-in completely parametric with some extra features.
Jorge_Jaramillo
I believe the issue is because you are using objects (axis entity and target body) from different components.
So you might need to supply the the rotation axis entity's proxy, instead of the object itself.
This is the code snippet I used to test it:
    comp = root.occurrences[1].component
    center_axis = root.occurrences[0].component.constructionAxes[0].createForAssemblyContext(root.occurrences[0])
    mci.add(root.occurrences[1].bRepBodies[0])
    comp.features.moveFeatures.add(mi)
Jorge Jaramillo
Software Engineer
joe_m_ferner
Thank you that did the trick with a little tweaking for my situation.
occurrence = comp.parentDesign.rootComponent.occurrencesByComponent(comp)[0]
center_axis = center_axis.createForAssemblyContext(occurrence)
It's weird I tried using "comp.occurrences" but that had length 0, going through the root design I was able to find it.
Full working example: https://github.com/joeferner/YAGA/blob/7508ae579650d30de0a052ee636684b2c1aec8a9/commands/spur_gear/s...
