Python Script - Traverse Assembly & Find "Part Quantity"
isocam
isocam
Can anybody help?
I have the following Fusion 360 "Python" script...
def traverseAssembly(occurrences, currentLevel, OutputString):
app = adsk.core.Application.get()
ui = app.userInterface
for i in range(0, occurrences.count):
occ: adsk.fusion.Occurrence = occurrences.item(i)
PartQuantity = ????
PartNumber = re.split(' v\d+', occ.name)[0]
PartDescription = occ.component.description
if occ.childOccurrences:
OutputString = traverseAssembly(occ.childOccurrences, currentLevel + 1, OutputString)
return OutputString
Does anybody know how I can get the "PartQuantity"?
Many thanks in advance!
Kind Regards
Darren
BrianEkins
If you don't care about where a part exists within the assembly and don't need the structure, here's a simple way to get a list of components and their count.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        des: adsk.fusion.Design = app.activeProduct
        root = des.rootComponent
        # Create a list of all components and their count.
        partInfos = []
        for comp in des.allComponents:
            refOccs = root.allOccurrencesByComponent(comp)
            partInfos.append([comp.name, comp.description, refOccs.count])
        # Show the results
        for partInfo in partInfos:
            app.log(f'{partInfo[0]}, {partInfo[1]}, {partInfo[2]}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I tested it on an assembly of mine with multiple levels and got this result. Most of the components don't have a description, so that's why the second field is empty for most of them. It also shows the assemblies, but you could filter assemblies out by checking if the component has any child occurrences and skip that component if it does.
 Biscut Joiner, , 3
 BackRail, , 12
 Large Shelf-Main, , 9
 Mid-Large Shelf, , 9
 LeftSide, , 6
 Jigsaw, , 3
 Bag, , 6
 22665T31, Vulcan Caster, Swivel, 4" x 2" Phenolic Wheel, 800 lb Capacity, 18
 Shelf-Edge, , 30
 CabinetMutilLevelTest v1, , 0
 PegBoard, , 6
 BackStile, , 18
 Router, , 3
 Pocket Hole Jig, , 3
 RightSide, , 6
 Tool Cabinet v32, Tool Cabinet, 3
 SmallShelf, , 12
 Mid-ShelfDivider, , 3
 Door, , 6
 Back, , 6
 Mid-Top, , 3
 Skeleton, Reference, 3
 TopBottom, , 12
 Shelf, , 12
 Brad Nailer, , 3
 Mid-Divider, , 3
 Mid-Left, , 3
 Mid-Right, , 3
 Mid-Bottom, , 3
 Mid, , 3
 Orbital Sander, , 3
 Finish Nailer, , 3
 Cabinet Skeleton, , 3
 SmallShelfAssembly, , 12
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
