Python re.split not working?
Le_Bear
Le_Bear
Doing this in the console works:
>> line = '0.9;0.0028'
>>> arr = re.split(',|;',line)
>>> arr
['0.9', '0.0028']
but the same thing in code does not, as I get this value for arr
['0.9,0.0028']
I do import re in code, and don't see any error about re not being imported, so I am not sure what my problem is?
Thanks for any help.
Bernard
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
burzins
Hi Bernard,
The code below gives me:
What does it do for you?
import adsk.core, adsk.fusion, adsk.cam, traceback
import re
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        line = '0.9;0.0028'
        ui.messageBox(str(arr))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Steve
Le_Bear
Yes, it's working fine. So my problem is somewhere else.I don't even know why I did not try a quick script to test as you suggested!
Found it! In fact I had a test on a string, before the split line, which was always false! So now it works just fine.
Thanks for pointing me on that small test.
Bernard
Bernard Grosperrin
