Python API Type help for sketchControlPointSplines.add
JWCampb
JWCampb
I am trying to add a Control Point Spline based on several points, but I do not understand the correct type for the `degree` parameter. According to this doc: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-8B8CD9F7-B4DD-44C0-A65F-90891072D18A I need to provide a `SplineDegrees` object, but I receive a TypeError with every permutation I can find, such as:
`sketch.sketchCurves.sketchControlPointSplines.add(points, adsk.fusion.SplineDegrees.SplineDegreeFive)`
kandennti
Hi @JWCampb -San.
I tried this, but no error.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        coordinates = [
            (-5, 0, 0),
            (5, 1, 0),
            (6, 4, 0),
            (7, 6, 0),
            (2, 3, 0),
            (0, 1, 0),
        points: list[core.Point3D] = [core.Point3D.create(*c) for c in coordinates]
        skt: fusion.Sketch = root.sketches.add(
            root.xYConstructionPlane
        splines: fusion.SketchControlPointSplines = skt.sketchCurves.sketchControlPointSplines
        splines.add(
            points,
        splines.add(
            points,
            fusion.SplineDegrees.SplineDegreeThree
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
My guess is that there is something wrong with the contents of "points"?
Jorge_Jaramillo
@Jorge_Jaramillo - this post is being edited to remove PII.
Hi @JWCampb ,
How did you define the points variable in your code?
Could you share the source code of the script and the full error message?
The degree in a control point spline defines the number of control points it needs to calculate every segment of the spline curve.
Jorge Jaramillo
JWCampb
Thank you -- you're absolutely correct (though I'm not sure why the error seemed to point to the SplineDegrees). Turns out I had my points in an ObjectCollection as would be used by sketchFittedSplines's add method.
