Pull post from linked folder
dames123
dames123
Is there a way to pull a post file from a linked folder using the API?
Thanks.
dames123
BUMP
boopathi.sivakumar
Hi @dames123
I think currently we don't have a support to read post from linked library via API. I will just confirm that.
Do you want to import the post from your local directory then use it? is it the workflow you are trying to acheive?
Boopathi Sivakumar
Principal Technology Consultant
dames123
Hi @boopathi.sivakumar
Yes. I have a script that currently pulls a post from the Fusion local folder and I would like to change that to a linked folder. Maybe @Jorge_Jaramillo has some insight?
#n360API Python script
import adsk.core
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    app = adsk.core.Application.get()
    try:
        create_and_duplicate_ncprogram(app)
        ui: core.UserInterface = None
    except:
      app.log('Failed:\n{}'.format(traceback.format_exc()))
def create_and_duplicate_ncprogram(
    app: adsk.core.Application,
) -> None:
        try:
            camObj: adsk.cam.CAM = app.activeProduct
            ui = app.userInterface
            # https://url.us.m.mimecastprotect.com/s/R9VIC2kr1Nf6PQk3I9ku4o?domain=help.autodesk.com
            ncPrograms: adsk.cam.NCPrograms = camObj.ncPrograms
            for setup in camObj.setups:
                ncIpt: adsk.cam.NCProgramInput = ncPrograms.createInput()
                ncIpt.displayName = setup.name
                ncParameters = ncIpt.parameters
                ncParameters.itemByName('nc_program_filename').value.value = setup.name
                ncParameters.itemByName('nc_program_openInEditor').value.value = False
                ncParameters.itemByName('nc_program_useMachineConfig').value.value = True
                ncParameters.itemByName('nc_program_filename').value.value = setup.parameters.itemByName('job_programName').value.value # Set the filename to the same as the setup
                ncParameters.itemByName('nc_program_comment').value.value = setup.parameters.itemByName('job_programComment').value.value
                ncIpt.operations = [setup]
                prg = ncPrograms.add(ncIpt)
                prg.machine = setup.machine  # Set the machine to the same as the setup
                app.log(f' {setup.name=} :: {setup.machine=} {prg.machine=}')
                # Duplicate the NCProgram
                duplicatedPrg = prg.duplicate()
                if duplicatedPrg:
                    camObj.ncPrograms[-1].name = f"{setup.name} SETUPSHEET"
                    postConf = import_post_processor()
                    if postConf:
                        camObj.ncPrograms[-1].postConfiguration = postConf
                else:
                    app.log(f"Failed to duplicate NCProgram for setup: {setup.name=}")
                    app.log("Dont forget to set your tool numbers")
            for prg in ncPrograms:
                app.log(f"{prg.name} : nc_program_post = {prg.parameters.itemByName('nc_program_post').value.value}")
            ui.messageBox("Dont forget to set your tool numbers")
        except:
def import_post_processor() -> adsk.cam.PostConfiguration | None:
        POST_PROCESSOR_DESCR = 'Setup-Sheet-For-High-Speed'
        POST_PROCESSOR_FILENAME = 'Setup-Sheet-For-High-Speed.cps'
        POST_PROCESSOR_URL = 'user://'
        camMngr: adsk.cam.CAMManager = adsk.cam.CAMManager.get()
        camLibMngr: adsk.cam.CAMLibraryManager = camMngr.libraryManager
        postLibrary = camLibMngr.postLibrary
        importedURL: adsk.core.URL = None
        local_url = adsk.core.URL.create(POST_PROCESSOR_URL)
        # 1. Look for post processor locally
        for url in postLibrary.childAssetURLs(local_url):
            if url.leafName == POST_PROCESSOR_FILENAME:
                importedURL = url
        if not importedURL:
            # 2. Look for post processor in Fusion's PostProcessors Library
            postQuery = postLibrary.createQuery(adsk.cam.LibraryLocations.Fusion360LibraryLocation)
            postConfigs = postQuery.execute()
            for config in postConfigs:
                if config.description == POST_PROCESSOR_DESCR:
                    # 3. If found it, copy it locally
                    importedURL = postLibrary.importPostConfiguration(config, local_url, POST_PROCESSOR_FILENAME)
        if importedURL:
            postConf = postLibrary.postConfigurationAtURL(importedURL)
            return(postConf)
        else:
            return(None)
adsk.terminate()
Jorge_Jaramillo
Hi @dames123 ,
What do you  mean by a "linked folder"?
Is it on your local hard drive outside of Fusion's environment?
dames123
Hi @Jorge_Jaramillo ,
Yes, you can link a folder on a network share for your team to access. I know I should probably use the cloud but I prefer a hard copy.
