Project points into sketch
brad.bylls
brad.bylls
Hello all, I am trying to project points from one sketch into another.
sketches = activeComp.sketches
newSketch = sketches.addWithoutEdges(xyPlane) # User selected surface
newSketch.name = strResult # strResult = 'Selected Sketch Name'
sketchPoints = moldBaseComp.sketches.itemByName(strResult).sketchPoints
newSketch.project(sketchPoints) # Line 57 (error)
Then I get the error message
I've tried several different things from the forum and help but can't figure it out.
Help please.
Brad Bylls
kandennti
Hi @brad.bylls .
Probably the proxy is not getting enough.
Here is the result of running the following sample with the attached file.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        moldBaseOcc: adsk.fusion.Occurrence = root.occurrences.itemByName('MoldBase:1')
        moldBaseComp: adsk.fusion.Component = moldBaseOcc.component
        moldBaseSketchName: str = 'Reference Sketch'
        resultOcc: adsk.fusion.Occurrence = root.occurrences.itemByName('Result:1')
        resultComp: adsk.fusion.Component = resultOcc.component
        resultSketchName: str = 'Result Sketch'
        resultxyPlane: adsk.fusion.ConstructionPlane = resultComp.xYConstructionPlane
        # create sketch
        sketches = resultComp.sketches
        newSketch = sketches.addWithoutEdges(resultxyPlane)
        newSketch.name = resultSketchName
        # create proxy
        newSketchProxy = newSketch.createForAssemblyContext(resultOcc)
        # get reference sketch
        moldBaseSketch: adsk.fusion.Sketch = moldBaseComp.sketches.itemByName(moldBaseSketchName)
        # create proxy
        referenceSketchProxy = moldBaseSketch.createForAssemblyContext(moldBaseOcc)
        # execute project
        sketchPoints = referenceSketchProxy.sketchPoints
        [newSketchProxy.project(p) for p in sketchPoints]
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
For more information about proxies, please click here.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-88A4DB43-CFDD-4CFF-B124-7EE67915A07A
brad.bylls
I only needed to change the last line to
Brad Bylls
